No Video,Retres Lines - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Retrace Line, faults & possible causes to TV screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 07, 2015
HORIZONTAL WHITE LINE ON THE TOP OF SAMSUNG ULTRA SLIM TV
My tv problem no picthire only retres line all screen no pannel opreting no remot work
May 12, 2014 | Samsung Ultra SlimFit 20" Digital TV
My dell lcd screen some lines vertical problem
We might be having issues with the video card or the LCD
For us to isolate where the problem is coming from
1. Tried accessing the BIOS see if the vertical lines are present
2. If there are vertical lines on BIOS definitely the problem is LCD and we to replace it
3. So if we see vertical lines inside Windows we might have issues with Video Card itself or Video Card driver
4. Try uninstalling the video driver and install a fresh copy of video driver. Else we need to replace the video card
5. Usually laptops have integrated video. So we need to replace Motherboard
Jun 02, 2011 | Dell Inspiron 6400 Notebook
Videocon tv using ic tda9370ps/n3 sevice menu code
have can open service mode in tv using ic TDA9370PS/N3/A/1932
Jan 06, 2011 | Health & Beauty
Grey lines during playback.
Camcorder video head required cleaning because gray lines come in playback when video head got clogged/ dirty.
Put video head cleaning tape and playback it as per instructions.
hope this will help you.
Thanks.
Apr 03, 2010 | Sony DCR-HC38 Mini DV Digital Camcorder
My tv pictur blinks on and off for about an hour and then stays on almost like the tube is heating up or something. Is this a capacitor or tube problem?
pls. check
[1]capecitor 10/ufd/250vdc replace
[2]check or resolder filament registance.
[3]check video trangestor on crt base is dry so pls. resolder.
[4]croma ic resoler itis posibel sum times. pcb after one or two hour heted and banding then is video singnal pin is dry or sperking
problum is not pictur tube becos pictur is on.
if pictur OFF WITH retres line then problum is in side of pictur tube and if yes then solusion is cathod and filament is sort after crt filamnent is over het.
this candetion 2 stap to folow and solve this problum
[1] filament registance velue is high for oregenal velue
[2] tube charging mathod to use and cathod and filament sorting is clear.
Jan 30, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Vertical lines on screen , is there a processor driver download to fix this problem
Vertical lines on a screen is not a processor problem, vertical lines is going to be a problem with the monitor or the video card. Try a different known working monitor on your computer and if the lines go away then you know that the original monitor is bad.
If the lines don't go away then try replacing the video card. If you have integrated video then the motherboard would need to be replaced. A processor driver download is not going to fix a vertical line problem.
Aug 08, 2009 | Dell Computers & Internet
Lines of print are overlapping. a couple of lines will be ok and then a couple of lines will overlapp
From what you are describing it sounds like a video driver issue. Have you made changes to your video driver or video settings prior to this happening? Have you tried a different monitor to see if it is doing the same? Check for updated Display Drivers for your system.
Dec 17, 2008 | ViewSonic Computers & Internet
Capture video from composite input
you should make sure everything that may cause interference is away from any of those cables, such as cable/dsl modem, wifi router..etc because they cause a large amount of electromagnetic interference
Nov 02, 2008 | Pinnacle DV500 DVD Video Capture Graphic...
Rca 32 inch tv
your problem is in red video output circuit.
as you are seeing lines with red color
those lines are called retrace lines.
please check
  • supply to red video output ckt.&red video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to red video output section
  • red signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 17, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
