Question about Pool & Spa
Bernzomatic pencil torch only wants to work when upright and only on high?
2 Suggested Answers
SOURCE: WE HAVE A BERNZOMATIC ST200
with the solder tip attached push upward on the little black knob on the tip, its spring loaded and on one side reveals a small little chamber where you can see a small flame once you turn the gas on and apply a spark/match to the little opening. keep the knob still pushed up all this time. let the fire inside keep going, if you let the knob down and the window to the chamber closes before it gets hot enough the iron wont work but if you wait for a bit with the fire inside, then right below the tip you'll start to see that area glow red, once its glowing red your good to go, you can close the chamber and the catalyst will "burn" the gas in the area and make heat instead of the fire heating the tip. once you close the chamber you're holding open with your thunmb then the fire goes out, if its hot enough you're set to go, otherwise rinse repeat.
Posted on Nov 01, 2010
Berzdomatic torch 1652 ownermanual
Try Googling (bernzomatic)(1652)(manual) without parens.
Aug 21, 2017 | Tools & Hardware - Others
How do i clean torch? thank you for any help
Ginoni Milan Serum If you use a curling iron or other heat tool on your hair, be sure that the products you use for cleaning, conditioning and styling your hair are heat-activated. Heated hair appliances used on a daily basis can damage your hair, if you don't take the proper precautions. Heat-activated products can provide your hair with extra moisture, and help to reverse the damage caused by high temperatures. If you plan to head out right after work, it is easy to get a fresh look by dusting some matte powder on oilier areas with a big brush. Make sure that you take care of your cheeks, as this is where a lot of oil will fester.
Read More >>>> http://www.wecareskincare.com/ginoni-milan
Dec 28, 2015 | BernzOmatic Micro Pencil Torch Kit 019132
I have a small pencil torch its not flaming right.not torching just a flame
Too much gas! Turn it down and check that nothing is blocking the airways.
Mar 23, 2015 | Blazer Pencil Micro Torch PT 4000
How to repair and assemble ST200 - Micro Torch bernzomatic
get the Bernszomatic guide it shows assembly.
ask them. its free, they dont want you to blow up, so is FREE.
id trash it. and start over.
but i use mine like that to test engines. just a valve and neck.
May 08, 2014 | Cars & Trucks
Micro torch
to little air - air holes blocked up
Feb 23, 2014 | Omega Bernzomatic Corporation ST2200T...
Torch doesn't have correct flame
Without knowing the specific torch tip you're working with and what you're welding/soldering the only thing any one can suggest is cleaning the tip. You can get welding tip cleaning files any where that sells welding supplies.
Dec 23, 2013 | BernzOmatic Welding Tools
My Ryobi string trimmer (CS26) starts fine but bogs down when it gets hot.
Try turning high speed screw (furthest out from engine) clockwise 1 quarter turn. Also check spark aresster screen. You will find it at muffler exit. Usually 1 screw holing it in. Remove it and clean, I use a bernzomatic torch to burn out deposits.
Oct 06, 2010 | Garden
Starts easily, but won't rev for 10 mintues. After warm, max speed is low / lacks power. New plug & gas filter
Check to see if the muffler is blocked.There is a screen (spark arrester) at muffler exhaust these get blocked. Usually 1 screw holding it in. Remove screen and replace or clean. I use bernzomatic torch to burn out these deposits.
Oct 01, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Bernzomatic 165w cordless(gas)soldering kit keeps going out even when full of gas
It sounds like the main orfice in the tip is partially plugged and causing a lack of fuel after startup, take the unit apart and using a torch cleaning set clean all the small openings and blow out any loose dirt or contamination you find and then try it. Be carefull when you clean out the orfice that you dont sratch it or deform it in any way as it will have to be replaced if this happens. Hope This Helps Don
Sep 03, 2009 | Welding Tools
Pool & Spa Logo
79 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
