Question about Dell E193FP 19" LCD Monitor
Dell monitor keeps turning off...
I ran across another thread on this website describing a problem similar to mine and I was hoping you might be able to help me.
Here is the link:
Following the suggestions, I took the monitor apart and was fully prepared to replace transistors, capacitors or whatever but I can't tell which ones to replace. There's nothing that looks "obvious." I took a few pictures and was wondering if someone might notice something that jumps out.
Incidentally, my monitor is about 4 years old (one year PAST the warranty...GRRRR). I did try hooking the monitor up to another computer and it does the same thing (goes out after about 2 seconds). I tried the flashlight test but couldn't see anything.
Honestly, I 'm getting ready to throw the darn thing out the window and go to Wal-Mart to buy another one as someone else suggested.
  • 4 more comments
  • SassyBrat1 May 01, 2008
    I have the same problem. If I power off and back on, it will display for a few seconds and then go black. Usually after 20 minutes or so, the screen would stay on. Now, even that doesn't work. My monitor is 2 months out of warranty. What a bunch of ****! I've tried driver downloads, setting power options, so nothing shuts down. Also the compressed air all over.
    Please Help!
  • travelerla Jun 01, 2008
    same problem .I tried to talk to Dell but dell rep told me that i did not buy from them that they were not to help me. thanks Ralph
  • ivy_del_vele Apr 19, 2009
    My Dell monitor has recently started powering off randomly. The screen will go black and the power light will turn orange for a couple of seconds then turn green again, but the screen is still black. I can still hear sound just fine but turning the monitor off/on does not help. I have to manually power the tower down. I can't find a pattern to this happening.
  • goinsag3968 Apr 28, 2009
    ok 15 minutes each morning i am turning the flat screen monitor off and on until it stays...i have unplugged cleaned and replugged everything back into it then a few more times of turning it off and on and wha-lah its on for therest of the day until tomorrow where i will have to start all over again...i bought in 2004 so now its 5 years old...why if so many of us have this problem is dell not responding.???
  • Anonymous May 16, 2009
    I've had this monitor for about 3 1/2 years. Now it lights up for about 1 second then goes black. If I turn it off and back on, it lights up for 1 second then goes black. If I unplug the cable at the computer, then plug back in, it lights up for 1 second then goes black. If I push the menu button on the monitor, it shows the menu for about 1 second, then goes black. The light stays green, does not go to amber.
  • knoxrebel May 22, 2009
    I also have the same problem, video is fine for a second then shuts off, its not a backlight problem though.
I have a similar problem, except if you look very closely, from an upwards angle, it isn't off, but on the darkest contrast setting. The Dell monitor that I am using has 4 buttons in the bottom right corner. The first is silver, the second is silver with a - on it, the third has a +, the fourth is larger than the rest and is the power button. If you press the first button, the menu will pop up. Then press the third button (the +) to go down to 'factory settings'. after that, press the blank menu button again, then the + to go down to 'all settings,' followed by the menu button again to confirm. To recap, press the first, third, first, third, first and it should fix your settings. This may only happen temporarily, and it may go black again. If it works at all, then it is the contrast getting out of whack and not the monitor shutting off at all.
Posted on Oct 18, 2009
I have somewhat the same problem and this is how I deal with it although it is only a tempory solution. First off let me explain my problem.
Problem: Sometimes Randomly when I Turn on my Tower & my Monitor it will start up just fine and show me the Sony Vaio Logo and then the Window's XP Logo but when it goes from the Window's XP Logo to the Desktop the Monitor goes from Green to Amber & shuts down. The power on the Tower is still on and I know it has started up because I hear the familar Windows Start Up sound. Restarting the computer with a Hard Shut Down doesn't work & it does this on more than one computer.
My solution although Temporary works and may have to be done again when the problem rears it's head again but this is what I do.
Solution:When you first turn on your Tower and it goes thru the startup process keep hitting F8 until a menu pops up and has a bunch of options. One of those Options will be to "Start your Computer in Safe Mode" Choose this option and it will restart your computer and you should be able to reach your Desktop. At this point at least in my computer it then askes if I would like to continue in Safe mode or go to Restore Mode & restore my computer to another date. I choose Yes & usually restore it to the day before and once it restores itself everything works for quite a while before it happens again.
So Having Restore points can be very important in this situation so make sure you computer if it has a System Restore Option makes system restore points at least once or twice a week because you never know when you will need it and it will save your **** rather than having to fully re-install the OS and lose on the info on your HD.
Goodluck & I hopes this hopes those affected. Maybe I will finally figure out the problem have a permanant fix one day.
Posted on Aug 02, 2009
  • 138 Answers
Ok I got the same problem. You may have to recheck shining flashlight again, not directly but find the best angle to the monitor and take a look very closly. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps in the monitor. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Another way to check this is that the heat component after you input the power and check the temperature. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 03, 2008
Wolf pack the problem you are describing is software. Uninstall your video card and reinstall it, you may want to do some virus scans too.
The original problem is probably hardware if you are taking it apart, cant help there, sorry :(
Posted on Nov 23, 2009
im not too great with computers so i was stuck,
rang up dell but they really dont know what theyre talking about
i really need help because i feel like punching through the monitor due to the annoyance of this problem.
Posted on Aug 07, 2008
Kids ran magnet across screen
Magnets do not affect LCD screens.
If your screen is a CRT monitor then a magnet will cause this problem.
Try turning off the monitor and back on several times and the degaussing coils on the monitor may fix this problem. If the screen is still discolored then take your monitor to a TV repairer and they can degauss your monitor with a more powerful degaussing tool.
Apr 05, 2013 | Dell Inspiron 1545 Notebook
When I turn on my computer the monitor light turns green then turns yellow. And won't come on.
I just had this same problem recently. As a computer tech I prefer fixing other peoples computers and NOT mine. Your case may be similar to mine. If you have a good monitor you will be hoping that it isnt similar to mine. Ok the short of it is either your monitor is bad or your video card is bad. First lets make sure we have covered the DOH items. These include making sure the video cable is plugged in all the way on both ends. Also make sure the video card has stayed seated in its slot on the motherboard. If Video card is integrated then this wont even be a possibility. Now take a known good monitor and swap it in. If you are like me you appreciate as big a monitor as you can get and hopefully you still have an old small one hanging around. If you dont have you you may need to borrow one from a friend or work. If the known good monitor works then your monitor has gone bad. It happens all the time. I have a stack of dead LCD monitors. some can be fixed and some cant. You can also take your monitor to work to test it with known good computers. Keep in mind that if the monitors are different sizes you will need to make sure the computer is shut off before plugging the monitor in. The system reads info from the monitor to make sure the resolution can be handled during boot. Your symptoms generally mean the video card is not working. The monitor light goes orange because it is not getting a signal. That signal can be interrupted in the monitor as well though. Testing will tell you which it is.
Aug 11, 2010 | Norcent Technologies Computers & Internet
The screen will not come on when the computer comes on on my dell xps notebook. The laptop comes on but the screen stays black when turned on.
I had a similar problem with a one year old Dell laptop, and it turned out that the screen was OK on battery power, but when you plugged it in to the AC charger the screen went very dark. It turned out to be the LCD backlight inverter, which I purchased from a fellow in Florida for about $16 and installed by following the instructions at . Hope this helps you out a bit...
Mar 29, 2010 | Dell Studio XPS 16 Notebook
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
Dont know how much gas i have in gas tank
Same thing happened to me. Keep an eye on your trip meter for gas usage, otherwise, change the sending unit.
I lost track of mine and ran it bone dry, causing the sending unit to overheat and quit working. Pain in the *** to do it yourself but cost effective. My Step by step instructions are in another similar thread. Hope it doesn't happen to you that way. It's an '03 Malibu, so it was going to happen anyway.
Jul 05, 2009 | 2003 Chevrolet Malibu
Power cord for Dell Monitor 2005FPW
I got this from the website at Dell. It looks like the cord you want is the second one. I'm basing this on the fact that normal operating wattage is 55w with a max of 74w and that would describe your second cord. The first one wold provide too much power.
VESA Modes
Horizontal Sync
Vertical Sync
Power Indicator
Power Consumption
Normal operation Active Active Active Green 74 W (maximum)*
55 W (normal)** Active-off mode Inactive Inactive Blanked Amber Less than 3 W Switch off - - - Off Less than 1 W(at 110 Va)
Dec 26, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
The problem you are experiencing is quite common, however the solution can be expensive and frustrating if you are not sure what you are doing. The problem is due to usually 1 of 2 things but the result is the same. The result is that the H.O.T. (Horizontal Output Transistor) is blown or severely damaged and needs to be replaced along with the item that caused it to go bad to begin with. Note: sometimes just the H.O.T. transistor can be replaced and it will work ok (this is rare and due to just being over-used).
The problems that caused the original issue is either the H.O.T. Transformer (a black device with heavy red wire insulation going between the mainboard and the picture tube with a wide boot on it). The other main culprit is the picture tube itself that will internally arc between the pins on the end of it.
These devices develops internal shorts that wipe out the H.O.T. transistor which is mounted to a heat sink.
None of your pictures show this board (it appears to be the same 2 boards in different poses). In your case it sounds like the picture tube is at fault and not worth repairing.
One other possibility is just poor soldering on the main board but this is extremely rare fault.
Hope this helps!
Rich Lilja
Nov 26, 2008 | Computers & Internet
Monitor display
You might want to check the refresh rate in your advanced settings under display properites. Under Windows it shouls be something like: Start Button > Settings > Control Panel > Display Then click on the Settings tab, and on that screen click Advanced On that screen, click on the Adapter tab. At that point, make sure the adapter listed matches yours, and refresh rate should probably set to adapter default. Hope that helps.
May 18, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E193FP 19" LCD Monitor Logo
12,903 people viewed this question
Alun Cox
