P-Touch 7100 cutter error
When trying to print my label I continue to get cutter error displayed on lcd. I have tried removing batteries and leave for 5mins but the error does not clear, does this mean my label maker is beyond repair? What I found on opening the label printer was the plastic foot the holds the electronic switch had broken, I glued this back together with a small amount of epoxy resin and now it is working again.
  • mwhite
    mwhite Apr 07, 2015
    cutter error is a mechanical fault that needs an engineer to look at it - send back to supplier for repair.
    Master:
  • 294 Answers
Just a (too late) suggestion: The cutter on the PT-7100 (and I think on every Brother Label printer that uses TZ tapes) has a replaceable blade. Sometimes just removing the blade and making sure the tape path is clear of gunk is all it needs.
Posted on Apr 09, 2015
Error condition power supply
Dear,
you have not mentioned, whether print continues with that error or it doesn printer..?
anyway,
first thing, check your power cable.
If that error is on, it means that label media or ribbon sort of errors.
try re inserting both ribbons and media.
if tat error is flashing and printer continues printing, it may coz of over heat of head..! if so try reducing the pressure of the head.
if you are using continous labels, then calibrate the media and ribbon sensor.
for more details, please reach us.
www.trridevlabelss.com
Feb 05, 2013 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Hi, I have a brand new SX4 with a rotary cutter. I am printing 2 types of tickets, one with a black mark and one with a notch cut out of the side (gap). The problem I am having is that when printing the...
Your problem is related to the size of your Tags.
When the label is fed to be cut, the notch is placed on the sensor. Since there is no paper the value recorded says no paper. Try to recalibrate the sensors or stick a piece of liner on the sensor.
Feb 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
The error light on the Epson TM-T88IV keeps flashing whats wrong with it?
The following is from the Epson Users Manual:
Troubleshooting
No lights on the control panel
Check the power supply cable connections and the power outlet.
ERROR LED on (not flashing) with no printing
If PAPER OUT is on, the roll paper is not installed or is near the end.
If PAPER OUT is off, the printer cover is not closed properly.
ERROR LED flashing with no printing (and no paper jam)
Printing stops if the head overheats and resumes automatically when it cools.
If overheating is not the cause, turn the printer off, and after 10 seconds, back on.
Removing Jammed Paper
CAUTION:
Do not touch the thermal head because it can be very hot after printing.
1. Turn the printer off and press the cover open button.
2. Remove jammed paper, reinstall the roll, and close the cover.
3. If paper is caught in the cutter and you cannot open the printer cover, open
the cutter cover as shown in illustration J.
4. Turn the knob until you see a triangle in the opening. This returns the cutter
blade to the normal position. There is a label near the cutter to assist you. See
illustration K.
5. Close the cutter cover.
6. Open the printer cover and remove the jammed paper.
Cleaning the Thermal Head
CAUTION:
After printing, the thermal head can be very hot. Be careful not to touch it and
to let it cool before you clean it. Do not damage the thermal head by touching
it with your fingers or any hard object.
Turn off the printer, open the printer cover, and clean the thermal elements of the
thermal head with a cotton swab moistened with an alcohol solvent (ethanol, or
IPA).
Epson recommends cleaning the thermal head periodically (generally every
3 months) to maintain receipt print quality.
It sounds like your print head is overheating. Clean as instructed above.
Oct 23, 2009 | Epson TM T88 Thermal Printer
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Zebra 4M Plus Pauses unexpectedly
try to run the manual calibratio from the setings.
run "manual calibration"
move the ribbon out from the sensor (with the print head open) and take out 3 or 4 labels from the rollar and put that blank label paper unther the sensors on the left,
say "ok"
wen appear "reload all"
put the ribbon and the normal labels on the correct possition, and say "ok"
try to run sext the sensor profile.
save data (twice on "setup button")
tur off, and on again.
Feb 12, 2008 | Zebra Z4M Printer
Letra Tag QX50 Error 1 message
Don`t close the back plane compleet, push print and pull on the tape, now it runs on mine. Close the back plane and everything is ok now, Good Luck!
Michel
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
148 people viewed this question
jasbo
jasbo
