Question about Sewing Machines
I ca't seem to get the tension right in my Bernina1300MDC
  • William Gilbert Apr 07, 2015
    Hi Nussrat Merajdin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Do you have a Manual?
    Master:
  • Sewing Machines Master
  • 470 Answers
Here is a link to some YouTube videos featuring your machine.
Possibly something will help.
Google
Posted on Apr 08, 2015
Hi please help me I can't get the tension settings correct on my Empisal 720c overlocker
Make sure you are using brand new needles.
Remove all the thread from your machine. [It is recommended to clip the threads at the spool before the threading path, raise the presser foot, and pull the clipped thread DOWN through the machine. Pulling thread up (both in the case of sergers and sewing machines) can damage the tension mechanism.]
ALWAYS RAISE the presser foot and re-thread from the beginning.
Verify that you are threading each thread in the order specified.
When threading each, be sure to give the thread an extra little tug when pulling it through the tension mechanism. (This helps seat the thread completely in the tension disk. Sometimes it makes a little pop when it seats. Can't tell you how many times I've had issues and discovered one thread was not seated.)
The standard tension setting for basic overlocking is the midway point on each of the tension dials. Every machine is different and things change with time and use, so this is a good place to start but you will have to "tweak" each thread to get them where you want it. When you are testing the tension, it always helps to use 4 different colors of thread so you can tell which thread needs adjustment. Once you get familiar with how each thread's stitches look and can recognize them, then you'll be able to eliminate the various colored thread. Everytime you change fabrics or stitch, you will probably need to test it first before using it on your garment or item.
If a thread breaks, it is usually best to remove all the threads and start from the beginning. Trying to snake a thread through the path out of order frequently fails. If you are experiencing issues, avoid the frustration and start over.
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
Make It Handmade Perfecting Serger Overlocker Tension
nancysnotions com
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwiG_L36jabQAhXBhlQKHY13DqIQFgg0MAQ&url=http%3A%2F%2Fwww.bernina.com%2Fen-CA%2FExperience-CA%2FSewing%2FSerger-projects%2FUSA-ca%2FSewing-Embroidery-ca%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-ca&usg=AFQjCNEKhoO_UogiusKWRlCGxMR8SrN5Nw
Nov 13, 2016 | Sewing Machines
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
I dont seem to be able to get the tension right
does it seem tight to just pull it thru or only when sewing
Jan 30, 2015 | Brother Sewing Machines
Thread for a rolled hem on the bernina 800d
HI
I would reccommend regular serger thread for the right needle (left needle is removed) and the lower looper. and use wooly nylon in the upper looper
The tensions on the needle should remain at 5-6 upper looper thread tension should be about 3-4
and the lower looper tension at about 8
contact me at Sewaway@shaw.ca if you have further quetions
Wayne Buss
Apr 22, 2010 | Sewing Machines
I have a brother XL-2600, I have used many sewing machines and never had any problems with getting the tension right, but with this machine, the tension is never right. I have bought the best thread, I...
Sounds like you have tried everything possible, be sure you are using an anti static needle on the delicate fabrics, if that does not work it really does mean fiddling with the tensions until you get it dead right
Nov 06, 2009 | Brother XL-2600
Loose thread tension
You should be able to sew with the tension on 4 for most applications. The only time I've had to change it is for elastic.  I usually sew elastic on 7.   In my experience, when the tension doesn't seem right, I've got the wrong needle for the fabric.  Needles are color coded.  The top of the shank will be yellow or red, for knit or woven fabric.  There will be a band below that of orange, blue or purple for light, medium or heavy fabric.  You want to make sure you have the right needle for your fabric or it isn't going to sew well.  The only things I haven't been able to sew on this machine have been lightweight jersey knit and a really high twist twill.  It would do five layers of twill, but since I'd used twill for the pockets too, it wouldn't do six layers where the seam met the pockets.  I had to get a friend to do that on a commercial machine.  Jersey knit it likes to stuff down into the bobbin case.  I've heard it would do it with a straight stitch foot.  Regardless, you have to pay attention to needle selection.
Mar 08, 2009 | Brother XL-3500
Euro-pro 464xc bottom tension loose
Welcome to FixYa!
Loose bottom stitches come from the top, not the bottom. Seems weird, but that's the way sewing machines work.
The dial tension should be set at the mid range and make absolutely sure that you have the machine threaded correctly. Both things will cause a sloppy bottom stitch.
Thanks!
If you find my solution helpful, I'd appreciate a FixYa rating....
Jan 15, 2009 | Kenmore 12102
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
