Question about Beko Washing Machines
Where do the wires go on a beko wm5100w on/off switch
    Genius:
  • Beko Master
  • 1,585 Answers
If theres only 2 wires they go no set way
Posted on Apr 19, 2015
4 Suggested Answers
SOURCE: BEKO WM5100W The pre wash light is flashing
hi - mine's just done this too; press and hold the two buttons above the padlock symbol until the light goes out. voila! that cost me 35 quid to an engineer but it's free to you... cheers!
good luck
Posted on Apr 29, 2010
Testimonial: "Thanks"
SOURCE: i have a beko wm5100w
Hi, I have just come back from holiday. I turned on my beko washing machine,power comes on and when it starts it switches off the main electric box.before i went away i turned off the main electric box. Is the machine broken and if so expensive job?
Posted on Dec 11, 2010
  • 6277 Answers
SOURCE: I NEED AN OPREATING MANUAL
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Mar 08, 2011
Testimonial: "thanks yes i got it eventually , it was for my friend thanks gill"
My beko wm5100w takes in some water then stops and doesn’t do anything else
Most likely a control board failure open it up and look for burned connectors
May 03, 2018 | Beko Washing Machines
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59
https://www.youtube.com/watch?v=rih6H1cpu9Q
Jun 12, 2012 - Uploaded by ilona ilona
problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 10, 2016 | Beko Wm & Wma Models Washing Machine Motor...
BEKO WM5100W , DRUM NOT SPINNING DURING WASH CYCLE
It could be carbon brushes or electronic fault.
Do you have ability to check carbon brushes?
Feel free to ask if you dont know how to do it.
Apr 07, 2013 | Beko Washing Machines
I have a BEKO wm5100w and it has started making an awful noise when draining. Its definately not the spinning, ust the draining. It also leaves the clothes with a funny smell. What could be the problem?
hello sound like there could be somethink stuck the in the pump like a coin or metal also check the filter if it has 1 and check the drain hose. hope it helps
regards
shaun
Mar 27, 2011 | Washing Machines
I NEED AN OPREATING MANUAL FOR A BEKO WM5100W.5KG A CLASS 1000 RPM
Good luck,
John C
Mar 08, 2011 | Washing Machines
Hello, I have a beko wm5100w and it seems to be stuck trying to pump out water. I have cleared the filter and pipes, but now I need to reset the machine. I have done the "switch off, turn to 90...
It could be a faulty thermistor (showing high temperature)
or water sensor fault that is causing the pump to run.
Just try and unplug it for 3-4 hours, and see if it resets itself,
if not replace sensors, and if that does not work, replace the main board.
Here is the manual:
http://laundry.manualsonline.com/manuals/mfg/beko/wm5100_1.html?p=21
This is the actual reset/diagnostic mode
https://www.youtube.com/watch?v=8C4J3leArY0
https://www.how-to-repair.com/help/beko-wm5100w-wm5100s-test-mode-and-error-codes/
Sep 05, 2017 | Zanussi F1045W Front Load Washer
I have a beko wm5100w washing machine and it keeps tripping the electricity
Nov 25, 2010 | Washing Machines
I can hear the water going into the machine but after after a short while the machine stops, the start pause button and the wash button flash and the machine stops. I have held down the start pause button...
Not an answer to your problem but i am having the same problem with me 20 month old beko machine - a different machine to yours. I have had an engineer out twice already paid for by myself to rectify the problem and now it has happended a third time. The engineer seems to think it is poor quality wire used. Good luck let me know how you get on.
Sep 29, 2010 | Washing Machines
BEKO WM5100W The pre wash light is flashing & I can't get it to wash at all! Please help!
good luck
Mar 13, 2010 | Washing Machines
Washing Machines Logo
62 people viewed this question
Top Beko Washing Machines Experts
micky dee
janman
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
