Don't explain in manual that came with the tv
Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV
is what helps remember what your code. If the TV is unplugged for an extended
period of time, it clears the internal memory, which in turn will reset your
child lock code.
Locate
it.
Try
child lock code.
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code
