Question about Furuno NavNet TZtouch TZT14 14.1" Multifunction Display
I have had a lot of problems with aeration and ended up getting a aluminium box made up for back of boat
To prevent aeration. This helped up to 27 knots and then it starts to break up
    New Friend:
  • 65 Answers
Tough to comment without more specifics.
Posted on Apr 16, 2015
Boat wireing
Aluminium is a ground,but what are you actually trying to ground ?
Aug 25, 2014 | Boating
Does anybody know what alum rod is best to repair a cracked weld on my C17 crestliner boat?
There is a product on the market called aluweld it melts at a lower temp to normal aluminium but makes a permanent repair as long as your hull is pure aluminium shouldn't have a problem look online and contact the sellers for more info
Sep 27, 2013 | Exact Fit Sharkskin Boat Cover For...
Our kitchen faucet has continued to lose water pressure over the past two weeks to the point that it's down to a trickle. We have removed the faucet to look for any clogging and there is none. what could...
You took off the faucet, but did you take the aerator off the spout? That's a very common trouble, especially if you have hard water with lots of minerals. The aerator screen gets clogged and your water slows to a trickle or is stopped entirely.
The aerator just screws onto or into the faucet, but you might need a wrench to remove it if it hasn't been off in a while. Tape the jaws of the wrench to keep from damaging the chrome unless you plan to replace the aerator. Once it's off the faucet you can take the aerator apart, noting the order of the pieces, and clean off the screen. Reassemble it and put the aerator back on and you should have your water back.
You might also just want to replace the thing; you can find replacements at hardware stores and home improvement places. Just take the old one along to make sure you're getting the right replacement.
Mar 12, 2011 | Microwave Ovens
Can I remove the screen filter in the kitchen faucet and clean it? A112.18.1M 2.26pm 8.33L 7MIN. I don't want to try to unscrew the part and find out I shouldn't have. How should I unscrew it?
Yes, the aerator (where the water comes out) can be unscrewed and removed from the faucet. I remove these and clean them out on a regular basis. If the aerator won't unscrew by hand, place a washcloth over the aerator (to prevent scratching) and carefully turn it with a pair of pliers. (Screw direction to loosen: Looking down on faucet, with pliers to the right-hand side, pull them toward you.) Make sure the rubber washer is properly placed in the top of the aerator after you have cleaned it out and you go to screw it back on. You normally don't need pliers to put it back on, as these are meant to be screwed on hand-tight. There might be several little parts inside the aerator to take apart and clean out, so be very careful to put these parts back together the same way they came apart. I find a toothpick is often useful to clean these out, as well as a cup of water to rinse them in.
Nov 10, 2010 | Price Pfister Home
Turning on this faucet, hot or cold, results in a split second of water flow, then it cuts off for full second, then it cuts back on. Adjusting the pressure of the water entering the system by turning the...
I would take the aerator off, and turn faucet on to see if the same thing happens. the aerator screws on the very end of faucet were water comes out. You may need channel locks to loosen, If your worried about marking up the aerator with scratches, then hold a cloth around aerator to protect the finish. Do not squeeze to hard with pliers. If there is a constant flow now with the aerator off, then your problem is a clogged up aerator. Disasemble, laying pieces out on table the same way they came out for proper reassembly, after cleaning.
Jun 27, 2010 | Price Pfister Marielle Kitchen Faucet with...
Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
Jun 24, 2010 | Light Outboard Motor Boat Bass Fishing...
How to get out aerators that are flush with end of the faucet
All aerators screw in, one way or another. If the faucet end presents as a cartridge screw on type, it will unscrew from the supply piping and is then further disassembled.
Those flush with the end of the fixture are either remoed from the end, or are removed by removing the nozzle from the supply piping (usually flexible/retractable) and then disassembled from the supply side.
Hope this was helpful,
--W/D--
Sep 14, 2009 | Kohler Plumbing
Kitchen facet has been losing water pressure.
Faucets are normally fitted with an aerator that screws on. These can get clogged with minerals from hard water and cause the problem you're having. Try unscrewing the aerator and removing it. It may be pretty tight, but it will come off. Slip-joint pliers with the jaws wrapped with vinyl tape to prevent scratching the chrome can help.
Once the aerator's off you'll probably find the water works properly. It might be possible to clean out the aerator, but the best solution is to get a replacement at a hardware store or big-box home improvement store. They're only a couple of dollars and a new one will be more reliable.
Please take a moment to rate this solution, and thanks for asking here!
Mar 01, 2009 | Price Pfister Plumbing
Furuno NavNet TZtouch TZT14 14.1" Multifunction Display Logo
223 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
