Question about Toshiba E-Studio 166 Digital Copier
WHAT IS OU ICON ERROR - Toshiba E-Studio 166 Digital Copier
Comment supprimer mon compte windos live
Votre question n'est pas claire : voulez-vous
- juste supprimer un compte utilisateur Windows avec lequel vous vous identifiez sur UN ordinateur (et qui se trouve ?tre un compte live.com, ou hotmail.com, ou autre), ou bien voulez vous
- r?silier un compte Microsoft (live.com, ou hotmail.com, ou autre) qui sont ind?pendants d'un ordinateur en particulier (que vous aviez probablement ouvert en temps qu'adresse mail, ou pour souscrire un autre service ou publication de Microsoft) ?
Jan 04, 2015 | Computers & Internet
My canon copier, model IR 6317, Shows the error code:E After e shows 0000 ,what is the problem? how can i solve it?
probleme four esseyer bouton poussoir carte mere voir l sortie feuille a gauche sinon 3 choises lampe de chauffage ou thermofusible ou thermista,nce
Oct 15, 2012 | Canon imageRUNNER 400S Copier
After refill canon 860 says ink is too low and does not print anything. how do i reset the printer to accept refill ink? error message is "U410" with an "x" on the BK catridge icon on the printer.
When it says "error U410 -ink has run out even though ou have refilled the cartridge follow this procedure:-
1.Press Ok to get past the above error message. The machine will take a few momets to do its own calibration, etc.
2.When it comes on line, Hold in the rest button for 5 seconds.
3.When you request a print job, it will still show that the ink is low, just disregard and it will go on to print as usual.
Dec 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
What is ou?
OU stands for Organizational Unit and is a part of Windows Server Active Directory. When you add an Organizational Unit to Active Directory, this allows you to create a category for computers, or for users, or both. For example, in a high school, I may create an OU for Students and have all my student accounts within this OU, and an OU for Staff, and have all my staff accounts in this OU. Now I can apply GPO's, or Group Policy Objects, to this Organizational Unit, such as Interface controls if I want to lock down student interfaces for example. You can also configure OU's with computers in them. So for example, I may join a set of teacher computers to the Staff Computers OU within Active Directory after these machines have been joined to the domain, and then apply a Policy on that OU that says that ONLY staff accounts may log into these computers to prevent students from logging onto a staff machine.
OU's are extremely handy because you cannot apply policy objects to just a single user or computer. OU's also help keep your Active Directory structure nice and clean.
Hope this helps!
Mar 17, 2009 | Microsoft Windows Server Standard 2003 for...
No spysweeper icon displayed on my taskbar
To uninstall Spy Sweeper (if you used the UCSF install) locate a file named SSECleanup.exe in the <RootDrive>\Program Files\SpySweeper Install\ directory. ou can search your hard disk for this file.
After which, reinstall the product.
Nov 06, 2008 | Computers & Internet
Monitor is showing large icons, large pictures and blurry images.
Go to Start >control Panel> display.
On the Settings tab,slide the resolutin slider to a higher number. Hit apply and it will show ou the difference and give you the option to accept or reject the changes.
You can change the size of the icons by going to Start >Control Panel > Display >Appearance. Then click on the advance button. There you will see a box to change the size of the icons.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 26, 2008 | Computers & Internet
Linksys CIT310 dual mode phone with Yahoo Messenger
ok , verify if you are loging in invisible mode, it can be that you are doing that , that's why you are getting the X next to the antenna.
Also plug and unplug your usb, device, may be resseting USB connection may help, also if ou have win xp service pack you may need to upgrade, since USB driver are upgrader on service pack 2
Mar 09, 2008 | Linksys CIT310 IP Wireless Phone
LSU ERROR shows in display panel
The Laser Scanner Unit or LSU is what writes to the surface of the drum. The glass above the cartridge inside the machine could be dirty. The mirror motor in the LSU could be bad or needing cleaned so it spins better. Laser diode could be bad.
Sep 20, 2007 | Office Equipment & Supplies
Toshiba E-Studio 166 Digital Copier Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
