Question about Home Security
How do i open my bunker hill safe
I didn,t turn the key the correct way. no batteries in and key stuck
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
SOURCE: Cannot get my Bunker Hill Safe open.
get the key number that is listed above the key hole and then call 888-299-3427 for a replacement
Posted on May 19, 2009
jyackle5
  • 8197 Answers
SOURCE: I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Posted on Nov 15, 2009
SOURCE: My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
Posted on May 13, 2010
SOURCE: have a bunker hill safe. battery died. lost
Remove the sticker on the front panel with the SKU number, behind it will be a small hole, use a small screwdriver to remove the screw, then carefully remove the number pad. You will see the place to use your key.
Posted on Dec 25, 2010
How can I open my Bunker hill safe 95824 with a battery failure ?
Call harbor freight in CA and they'll let you know if there is a cure. They have an 8xx number for ordering parts and such, which is also their 'tech support' line.
Aug 15, 2014 | Computers & Internet
I have a bunker hill safe ,item# 91006,batteries too low,no key, drilled out overide lock,still won"t open, now what?
you can also get some wires feed him into the back contacting the battery terminals hold in there with a 9 Volt, four hands and patieance and then..... you get my drift. Worked for me! :) $
Dec 26, 2012 | Computers & Internet
Jan 30, 2010 | Check Point Network Adapter
I have a small bunker hill digital floor safe. I
follow the following link: http://www.harborfreight.com/manuals/91000-91999/91006.pdf you will see a picture of the bunkerhill digital floor safe, ITEM 91006-6VGA, under the sale price, you will see in GREEN "download product manual. There you will find the instructions for this safe. It took me about 30 minutes to find, then realized I didn't have batteries inside. Lucky for me, I found the key. You will need batteries inside. Otherwise, call the company Monday-Friday 9:00am - 7:30pm EST at 1-800-444-3353 (toll free). For Technical information call Monday-Friday 9:00am - 4:30pm EST at 1-888-299-3427.
Nov 02, 2009 | Check Point Network Adapter
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
CANT UNLOCK BUNKER HILL BOOK SAFE
Battery died and i can't find the key or the instructions to open the safe
Sep 22, 2009 | Locks & Locksmithing
Are all bunker hill safe keys the same?
Never!.............sodeep (unless you happen to be the lucky one in a million)
May 16, 2009 | Check Point Network Adapter
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Nov 21, 2008 | Check Point Network Adapter
Bunker hill safe
Sep 20, 2008 | Check Point Network Adapter
Home Security Logo
105 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
