Question about Baby Gear
Chassie of buggy will no longer fold.
Red stopper catch has been flicked up as per the manual, but the black catches on each side don't squeeze and release to fold.
2 Suggested Answers
macnutz
  • 541 Answers
SOURCE: handle has two release catches,for folding buggy
www.fixya.com/support/r7805199-fix_bugaboo_handle_lock
Posted on Sep 05, 2011
Is 1 1/2 inch door too thick for this hinge? Can I chissle down the edge of the door? Also, do you turn the adjustment device toward the door or away from the door? Do you need two pins per door?
Replace Only the door not the jam. right...?
Original is 1 1/4" thick. The new one is 1 1/2" thick.
It's 1/4" thicker. (It'll bide the stopper) So measure the hinge plate rout out, how deep on both (the door and the jam.) If it's same then you have to remove the stopper and re bore the latch hole more to the stopper side to catch center of the latch.
Is it make sense...?
Good luck
Mai
Apr 11, 2017 | Cars & Trucks
Whirlpool AWZ412 (1200): How do you remove the soap dispenser? I need to clean the water inlet holes above. I've tried lifting it and squeezing it. But there seems to be catching on the left side, and...
This is a common problem with many machines.
Try the following- in the second and third cases whilst looking from underneath!
Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit).You may have to push the bottom of the dispenser upwards.
  • lift upwards on the tray as it is coming out to clear the lip underneath. Again you may have to push the bottom of the dispenser upwards.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 15, 2011 | Whirlpool AWZ412 Front Load Washer
How do you disassemble the Cosco Funsport Play Yard?
Steps to disassemble.1) Pull up on the loop in the center.2) Flip the Funsport upside down3) Pick a side and pull the corners up slightly while pushing the center down. Sides can only move up about an inch.4) Press the release catch in the center of the bar.5) Pull the center of the bar up while holding the release catch in. Sometimes you have to wiggle the catch in and out to get it to release.6) Repeat for each side.7) After each side is collapsed squeeze everything together.8) Place the cover on the floor black side down.9) Put the Funsport on the cover with the plastic corners flush with the edge of the cover. The wheels should be sticking out the bottom.10) Wrap the cover around the Funsport and secure the velcro straps.
May 16, 2011 | Cosco Beatrix Potter Playard Crib
How do you fold this twin stroller?
1. Loosen the plastic catches on both sides
2. Push up the red safety lever and fold the seats in half
3. Step on the top rim of the rubberized, lower compartment of the buggy to fold the frame
Jul 25, 2010 | Valco Twin Runabout ATS Jogger
Help to fold down buggy
Hi, apply the brake.
Go round to front of buggy.
Hold the 2 large grey buttons on side of frame.
1 pushes down 1 pushes forwards do this & pull buggy down towards you, this will fold it as long as the brake is on.
Jul 22, 2010 | Quinny Buzz Three Wheel Stroller
Urban mountain buggy double stroller
THe Mountain Buggy is very simple to fold. Level with the footrest, there is a black plastic button (either side), these simply push toward the back of the pram and hey presto! The pram will collapse. To make this as small as possible, keep the front two heels on swivel so that they tuck neatly underneath and the handle bar adjusted to the lowest position.
See this link to help a little more.
http://www.mountainbuggy.com/customer-support/how-to-use/
I hope this helps.
Aug 29, 2009 | Mountain Buggy Urban Double Stroller
I can't remove back wheels on a baby jogger 2 buggy HELP!
There are metal clips near the back wheels that go around the black plastic "axle" piece of the stroller. Squeeze the clip to the far side of the axle and the wheels will easily come off.
Apr 27, 2009 | Baby Jogger 2 Stroller
The upper thread no longer catches the lower thread
Check the needle to be sure it is installed per the manual.
This is usually with the flat side of the shank facing the back of the sewing machine.
Last resort - take the machine in for service as it could be the timing needs to be adjusted.
Jun 03, 2007 | Euro-Pro 382 Mechanical Sewing Machine
Baby Gear Logo
27 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
