I can on the machine but it doesn't wash my clothes and i dont have a manual
Top load
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Try jimmys.com
Posted on Apr 13, 2015
Clothes bind around spinal
Perhaps you are over-loading the machine; put in load specified in manual, and distribute evenly.
Apr 29, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
I have a MHWE500VW11 and I hate it! It doesn't get the clothes clean. Give me my old top loader any day. I have to over wash everything on steam clean and it's killing my clothes. I do more dry...
One thing to check is the capacity of the machine. If you used to have a top loader you may be used to packing more clothes in, and the front loader may not be able to clean the same capacity.
Your manual should indicate the maximum weight of clothes for each kind of load. For example a 40 degree mixed load should usually weigh less than a 40 degree cottons load.
If you try washing less in each load you should find your clothes get cleaner.
Jul 25, 2011 | Maytag EPIC MFW9700S Front Load Washer
All the water does not spin out of the clothes & at times it doesn't even seem like it is spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 07, 2011 | Whirlpool LSR6334LQ Top Load Washer
The washer will not stop filling up with water and spilling water on the floor unless manually stoped. Sometimes it spins and rings the clothes out and sometimes it doesn't . With either problem it...
Remove front of machine with putty knife/slide knife in at top of front on left and right u will see the tabs.. there is a pressure tube that attachs to tub on the left side remove tube. DONT BREAK OF THE *** it is most likly pluged use small wire to clean tube and the little *** that it gos on to// put tube back on (SPIN AND DRAIN MACHINE) test on all load sizes.. good luck thank you for voting.............................
May 21, 2011 | GE Washing Machines
Doesn 't spin
Hi just read your posting.Just a couple of questions.Does your machine drain the water out?Does the machine beep and show an error code in lights?Please reply with additional information and I am sure I can help you rectify this fault.
Jul 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine is not ballanced. every load
There is a balance spring that keeps the machine balance. it broke or rusted and came off. Lean the machine back 45 degrees and look under
you should see the spring. reattach the spring to the base and the back. (you need to look at a manual if you dont understand) but try your best
Mar 22, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
