Question about Dell Computers & Internet
Acerlaptop isconnected to a dell monitor At first it worked well but then when I turn it on shows all the starting process but at the password screen isstuck on self testfeaturecheck. How do I fix it
    Sergeant:
  • 291 Answers
As a laptop is involved, you may have bent a pin during connecting and disconnecting the monitor to the laptop. Check that out.
I assume you have tried cycling through the adjustment screens using the buttons on the monitor.
Before you try replacing hardware components, you might try "last good configuration" on your computer via F8 on start up.
Posted on Apr 07, 2015
proton77
  • 1183 Answers
SOURCE: problem with Dell 2100FP LCD monitor
Dell support , would recommend you to buy a new monitor because , they donot do any repairs on the LCD monitors., except for exchanging them, if they are in warranty. You can try the following people , they do repairs on dell flat panels
http://www.lcdrepair.us/
Thanks
proton
Posted on Nov 26, 2008
SOURCE: dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Posted on Mar 10, 2009
c_robertson
  • 123 Answers
SOURCE: Monitor gone black but shows self test not floating
Sounds as though the control unit has died. There are 3 parts to most monitors. The video processor board, power supply board and the HV/backlight board. You can replace the video processor board.
Make sure you leave the unit unplugged first and set for an hour. Usually no other fix then replace the board.
Posted on Apr 29, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
najah
  • 180 Answers
SOURCE: My computer monitor will not stay on.
The problem may with the Ram inside your computer
Posted on Jul 07, 2009
Dell dimension 4700 pc monitor screen turns black
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 23, 2012 | Dell Dimension 4700 PC Desktop
Problem with Dell 2100FP LCD monitor
Unplug monitor form AC outlet, wait for few minutes and plug again.
Check cable attache to PC.
Hope this trick will work.
Sep 30, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
My dell monitor screen, s2209w, is blinking and asks for password
Check in in the BIOS,(Press F2 key during the start up) if the same thing u see in than BIOS replace the monitor.
Aug 01, 2010 | Dell S2209W Monitor
My monitor now looks yellow and won't go back to a white color? how can i Fix it.
isconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .also check you warrenty usually its for 3 years
also try to reset to factory settings by using the buttons on the monitor
Apr 23, 2010 | Gateway FPD2275W LCD Monitor
My dell vostro 1510 asks for HDD password. When i give it,a black screen comes and asks to choose from following a)start windows safe mode b)start windows normally and so on... After entering choice XP...
Oh boy, you need to call dell for that. the hdd is locked and only dell can give you the password. dont try unknow passwords its not gonna work. the password is related to the secuity of the machine. call dell and they will give you the password. in case by any reason you cant call dell. you need to repalce the hdd then. call dell they will give you the password free.
Oct 02, 2009 | Dell Vostro 1510 Laptop
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell wont start up
On the back of the chassis, there are 4 LEDs above the PS2 connections marked ABCD what do they indicate? During the boot process the lights normally flash on and off green, when the boot process is complete, they should all be green GGGG.
If any are Amber then they are indicating a power on self test (POST) failure. AAGG is bad memory for example.
Post the indications
Aug 06, 2008 | Dell Dimension 4600 PC Desktop
Thanks
proton
Aug 02, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Computers & Internet Logo
46 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
