Question about Salton Melitta MEU45 Stainless Steel - Coffee Urns
I can't seem to find any parts for my coffee maker .i need a basket,a pump tube,spring and a speader.
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Cuisinart grind & brew - spring in the filter area popped out. not sure where it goes?
Yes, you place the spring into the tube at the back. When you replace the basket holder, make certain you reach in behind the holder and guide the spring into the proper place on the holder. (Otherwise the spring will be forced to a permanent bend and not work as well. Can't find replacements for this spring on Cuisinart's website).
As for why it pops out better now, when you removed the basket holder and cleaned it, you also cleaned the plastic guides on each side. In normal use, these guides acculuminate coffee and tend to get sticky or gummy. When the door pops open, the sticky rails grab the guides and slow the sliding action.
Cleaning them restores the clean guide rails to slide open on. (Next time you clean the basket holder, remember to reach in and wipe out all the inner parts, including the plastic rails that the basket holder slides out on. These get coated with coffee as well. And the place around where the grind basket fits over the ground basket. This area always gets sticky with old coffee. Just use a wet paper towel and clean everything. (But remember to be careful when you reinstall the basket holder so that the spring fits back properly.
Dec 04, 2017 | Cuisinart Grind and Brew 10 Cup Coffee...
My unit seems to go thru the steps but stops at the point of discharging the water into the filter basket.
it's the check valve with the metal spring on the top. cut the tie wraps and put the tubing into the water fill area and make a small cup. water will be hot so watch out.
any ideas where to get replacement parts?
Jun 30, 2011 | Keurig B60 Coffee Maker
FCP-240,280,412 Farberware Percolator, 3 Prong Cord is too heavy for the percolator. It sometimes comes loose and we have cold coffee. Also the Spring on the Pump Tube does not stay in place. Any Help?
HI, on the plug, is it the part that pluges into the wall or the pot. By the model # you have 3 China pots. On the pump just below the coffee basket, take a pair of pliers and put the basket on the tube , now just make small crimp just below the basket,just enough to make it out of round., you will make it so the crimp will not let the spring or basket go by. If it is the plug going into the wall just bend the 2 flat outward so the plug fits snug. Good luck . Ron
Jun 20, 2010 | Coffee Makers & Espresso Machines
The basket bottom spring-came aprt
it's broke. you didn't say what kind it is, but it's probably cheaper to by a coffee pot
Aug 06, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
How do I put the spring back in that holds the door shut.
The replacement basket costs around $6.00 - don't fiddle with it, just a buy a replacement part from Cuisinart's website.
Nov 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
We bought a black&decker Spacemaker coffee maker last month and it has not worked properly but maybe a week. It seems to not want to flow correctly into the pot. We set it to come on and wake up to...
If the hole in the bottom of the basket isn't plugged, it sounds like the anti-drip feature isn't functioning properly. This is the series of levers that allow you to remove the pot while the coffee is perking without spraying liquid everywhere.
There is a vertical lever mounted at the back of the hollow where the pot goes, and the top end of that lever lines up with the spring-loaded lever that closes the bottom of the coffee basket. When the basket is in place without the pot, the bottom of the basket remains closed. When the pot is inserted it presses against the back lever and the series of contacts opens the valve covering the hole in the bottom of the basket, allowing the coffee to flow into the pot. If the sequence of contacts doesn't work the basket will overflow, and you get coffee and grounds everywhere.
Ensure all these parts align and are working properly. If there's a problem that can't be resolved, or parts are broken or missing, removing the spring-loaded lever from the basket will allow the coffee to flow into the pot. You will no longer be able to remove the pot while it is perking, but you'll have your morning coffee.
Apr 16, 2008 | Black & Decker SpaceMaker ODC150 Coffee...
Water heats but stops perculating
Check the spring under the grounds basket on the pump tube. This is supposed to hold the end of the tube down in the heater well. It should compress when the lid is pushed down on the basket and twisted to lock in under the handles.  I have found a good source of parts for Faberware urns and percolators at goodmans.net. The thermostats and heating elements can be easily replaced and the urn returned to original condition. Rich of Colorado
Dec 26, 2007 | Faberware 12-55 Cup Coffee Urn
Filter basket
You can find ODC325s on ebay just for parts since the heating element is shot. I don't believe those parts are for sale anymore.
Jul 21, 2007 | Black & Decker SpaceMaker ODC325 Coffee...
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Gil Shultz
Jay Plesset
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
