I have an Edina snack and chip machine I am looking for coin mechanisms that accept more than 4 quarters or one loonie where would I find them?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check on line for coin mechinesims or such
Posted on Apr 13, 2015
I have a speed queen commercial washer and a quarter is stuck in the holder how do you release it
is it a slide coin mech? If so
7/16 top center of service compartment
is the slides retaining rod
Once you have access to the coin mechanism.
the coin release will move slightly outward allowing the coin to fall into the return shoot
Jan 12, 2018 | Speed Queen Washing Machines
I have a Mercato 2000 Snack Vending with Summit 300 Satellite Drink Machine. The coins do not deposit into the dispensers. It collects at the top. How do i get it to drop into the dispensers?
you may have a coin jammed in the coin reader device. I know absolutely nothing about your machine but am a gaming attendent and have the same type of fault occuring on gaming machines from time to time. Foreign coins or bent coins also can jam up the reader.
check if the coin reader can open up to release coins.
Jun 17, 2015 | Retail Supplies
Hi, I have a pavilion dv9743cl. all of a sudden it will not turn on at all. No lights at all. the only light is at the power cable, just lights up blue. I've tried a new battery, and power cord, and still...
I love this machines. I have the DV9933cl the following it will be a lenghty process but if successful on following instructions you will be happy with the results and a little more computer sabby.
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP /DV9000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
this is the same issue that the Xbox 360 has with the power rings over heating. also to maintain your computer at a lower temperature never leave your computer on your bed. All the vents are cover so no air goes in and this happens it over heats
Jun 13, 2010 | HP Computers & Internet
Change the number of coins to operate
you need to take the coin slot apart take pictures as you go to put back together the parts to change amount are hidden inside it in hidden compartment if they wheren't removed by some one. your machine didn't come with the coin mech so if you don't have the parts you will need to take it with you to the parts house to get right parts. open the top of the coin mech box there are 2 long rod screws holding it in place usually 5/16 inch wrench fits may need to wiggle the heck out of it to get it out
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Computer is on (altho the wireless light is orange) but the monitor will not come on
HOW TO FIX YOUR DV6000/DV9000/DV2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
www.wnycomputerpro.com
Nov 28, 2009 | HP Pavilion dv9000z Notebook
My HP Pavilion dv6500 is running but lcd screen stay black only power light is on I press any bottton but nothing happen,power off then on,stay same... Thanks Milan Detroit
All the Problems described in the previous posts are Graphics Related..
Nov 22, 2009 | Toshiba Satellite P105-S9722 Notebook
When I start the laptop the light comes on but the screen stays blank.
Nov 16, 2009 | HP Pavilion dv9000z Notebook
I got a washer/dryer from a freand and its the one thats takes 1.00 for both how can i make it work with out having to put money in all the time
Depends on the coin mechanism. If it's a coin slide that you put all 4 quarters in then push the slide back, then there are two solutions. First, and best, would be to fill the quarter slots with blanks, then you could just push the slide when you need to start it. Second would be to just take off the service door and you would be able to reach your hand in and push on the same mechanism the slide would, of course you would need to keep your hand away from any wiring to avoid a possible electric shock. If it's a coin drop, where you put one quarter in at a time and the unit counts the quarters as you put them in, then you wouldn't be able to just start it, but you could reprogram the board accept just one quarter instead of 4, and you would need the manual as each manufacturer has a different process to do that.
Jul 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
