Question about Orion Car Audio & Video
How much air space from 12 orion cobalt series 1600w dvc
    Problem Solver:
  • 25 Answers
Box size? look it up on google in the specs or manual for your sub. it should say whats it is. bigger is better unless you have a sealed box or rubber surround
Posted on Apr 28, 2015
5 Suggested Answers
catally733
  • 117 Answers
SOURCE: how do i run a dvc sub with 2 mono amps? I have 2
each amp has + and - and will go to one of the voice coils , for the other voice coil use - to + FROM THE OTHER AMP , SET GAINS TO FULL COUNTERCLOCKWISE SO U NCAN LEVEL MATCH AMPS TO HEAD UNIT . REASON ONE VC IS WIRED "OUT OF PHASE IS SO THE CONES PUSH AND PULL WITH EACHOTHER
Posted on Oct 25, 2009
  • 5603 Answers
SOURCE: I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Posted on Oct 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: need to know the air space that is required for
Sealed = 1 cu ft.
Ported = 2 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Dec 29, 2009
  • 155 Answers
SOURCE: how much air space is recommended?
check out the subs spec at orion website online.....
Posted on May 12, 2010
I have a orion hcca 12.4, dvc 4 ohm sub, can I put a dvc 2 ohm recone kit on it even though its a 4 ohm dvc sub?
In most cases yes as long as coil and all are the same ive changed my HCCA orions from 2 ohm to 1.
Dec 15, 2011 | Orion Car Audio & Video
Hi there, i have a orion cobalt 2105xp 400. i have hooked all up, but very little bass. i have 1 10" boston acoustic sub. i noticed that the led is constant red, is it supposed to be green, crossover...
amp is in protect mode. check your wiring and make sure your sub is wired properly for ohms. dual 4 ohm in parallel = 2ohm. dual 4 in series is 8 ohms. dual 2 ohm parallel= 0.5 ohms and in series 4 ohms. check ground and power wires. make sure sub isnt blown. a blown sub WILL cause this on any amp.
Sep 10, 2011 | Orion Cobalt 2105 XP Car Audio Amplifier
How much air space is recommended?
May 06, 2010 | Orion Xtreme XTR12 Car Speaker
How much air space
Air space needed around the sub is a minimum of 1 inch, but 3-7 is preferred. If you get too big you can get an echo sound. Sealed is my preferred box - it generally gives you the deep base thumping you are probably looking for.
Hope this helps! Rate my solution!
Jan 05, 2010 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
Oct 26, 2009 | Orion HCCA 12D Car Speaker
How do i run a dvc sub with 2 mono amps? I have 2
Oct 25, 2009 | Car Audio & Video
How many svc subs at 4ohm does it take to get this amp to 1ohm stable and can you reccomend a good sub combo for this amp whether it be dvc or svc
It depends if your sub is 4ohm svc, or 2ohm svc. 4ohm would take 4 subs wired in parallel, 2ohm would take 2 subs wired in parallel. But for a amp that big, subs that'll handle it are definitely gonna be dvc. I'd recommend 2 Orion 4ohm dvc hcca's. They come in either 15in or 12in. the 15s are louder if you have the space for them. As far as wiring goes, wire the voice coils on the subs in parallel to 2ohm per sub, then wire the 2 subs in parallel to 1ohm. Goodluck and congrats on the equipment, Orion is about as good as you can go for subs and amps. just be ready to lay down some dynamat cuz this system'll bloww your vehicle apart! good luck...
Oct 08, 2009 | Orion 2500D Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion Deep Space explorer 8" manual
I have a scanned copy of the instruction manual for the Deep Space Explorer 6" and 8" telescope.
The manual is dated May 12, 1993.
If you would like, I will be happy to send it to you.
Not sure how to do this without broadcasting my email to the universe, but I will check back here later to see what can be done.
Aug 05, 2008 | Optics
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Car Audio & Video Logo
259 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
