Question about GMC 2005 Sierra 1500 SLT
Reset computer 05 GMC sierra?
Computer reset?
  • 117 Answers
SOURCE: Looking to put the gas
Yes. most of the time, these types of sensor are potentiometers = have variable resistance depending where the sensor is ready. if you are able to hook up a volt meter to the sensor and see the ranges match up with the old one, then the should be compatible...same as with gas tank sending units
Posted on Jul 07, 2009
  • 753 Answers
SOURCE: how do you reset the computer on a 98 gmc sierra
One way is to remove any fuses that say ECM/PCM in the fuse block and let them out for 20 minutes or more and another way is to disconnect the negitive battery cable and touch it too the positive. or pull all the connectors off the pcm.
Posted on Nov 01, 2009
BuzzFlewhart
  • 655 Answers
SOURCE: 2004 GMC Sierra Computer reset ??
I would suggest stopping by an AutoZOne or O'Reilly's and "borrow" their Scan Tool to erase any codes.
TO reset the "Change Oil" light, turn the ignition to ON (do NOT start the car). Press the accelerator pedal all the way down (then release) to the floor 3 times in less than 5 seconds. Change Oil light should flash then go off. If not, try it again. The trick is to get this done in 5 seconds ro less.
Posted on Apr 01, 2010
Testimonial: "One question answered correctly but the second question was misunderstood."
  • 462 Answers
SOURCE: The check exhaust filter light came on in my 2007
There is a procedure for your exhaust system. Its called Diesel Particulate Filter (DPF) Regeneration. Your dealer will have to do this for you. The particulate filter is in the exhaust system. It traps large carbon particulates so they don't get out into the air. The system is designed to take care of itself but does need to be done by someone with a tech2 scanner.
Posted on Apr 08, 2010
richard3707
  • 70 Answers
SOURCE: 93 gmc sierra running rich no computer codes
Oxygen sensor[s],map sensor and fuel pressure regulator.Although you should have a check engine light "on" with any sensor malfunction.I would look at fuel lines for a leak under vehicle.
Posted on Apr 17, 2010
Oil pump on 05 gmc 1500
it's in the oil pan usually .
Mar 21, 2016 | 2005 GMC Sierra 1500 Hybrid
05 gmc sierra 3500 6.6 duramax had the service 4wd abs light and eBrake light come one also the line showing what gear its in went away shut the truck off went too restart and truck wouldn't start jumped...
You probably have a trouble code stored in the engine computer for a faulty transmission selector switch. The engine computer thinks the trans is in 3rd gear and not park. Or it really could be stuck in third gear.
Aug 24, 2014 | 2005 GMC Sierra
How do you reset a check engine light on a 2008 GMC 2500 HD Sierra
Check engine light will go out when the management computer detects no more errors. Pull the codes and repair what they indicate.
Sep 12, 2010 | 2008 GMC Sierra 2500HD 2WD
The check exhaust filter light came on in my 2007 GMC Sierra truck 2500 duramax. I do not have the owners manual but I know the dealer will just reset the computer in the truck. How can I reset it myself?
Apr 08, 2010 | 2007 GMC Sierra 2500HD
Apr 01, 2010 | 2007 GMC Sierra Classic Denali
I changed the oil and do not know how to delete the message, is ''change engine oil'' in the display panel. what can I do?
Chevrolet Suburban/GMC Yukon XL, 2000-05 Chevrolet GMC Trucks Silverado, Sierra, 1999-05 Chevrolet Venture 2000
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Good luck and please rate. Keep me posted, and thank you for using fixya.
Jan 14, 2010 | 2004 Chevrolet Silverado
How to reset the change oil light on a 2003 chevy silverado
Information courtesy of synthetic-direct.ca
Best of luck.
Greg
Jul 15, 2009 | 2003 Chevrolet Silverado 1500
Looking to put the gas pedal and sensor from 06 GMC Sierra into a 05 GMC Sierra. The 05 is faulty and the 06 was free. I was assuming it would work due to it being the same truck. I did take in...
Jul 07, 2009 | 2005 GMC Sierra 1500 Hybrid
GMC 2005 Sierra 1500 SLT Logo
319 people viewed this question
Top GMC Computers & Internet Experts
bigdawg7299
Jeff Armer
David Ellis Rhea
Are you a GMC Computer and Internet Expert? Answer questions, earn points and help others
