Acer Aspire 5100 PC Notebook
Problem for Acer Aspire 5100 PC Notebook
BLue screen and shutting down with webcam
By Laalaaee on Nov 14, 2007
abotu 50% of the time, when i have the webcam on , wether it is over messenger or orbicam the screen well turn blue with white line and the computer will just shut down.
anything to do to help it? its VERY annoying.
Same Problem
Nov 21, 2007
-   im gettin the blue screen as a result of an orbicam problem (i think it's an elexctrical wiring thing). the computer keeps detecting and disconnecting the orbicam everytime i tilt the screen and eventually i just get the blue screen. anyone have a solution? yrubinucf@yahoo.com-   yrubinucf
Solution #1
posted on Nov 14, 2007
Somewhat Helpful)
shugster
Rank: Wiz
Rating: 79%, 97 votes
to be honest it sounds as if its a driver issue
try looking for an up date for the cam driver then
see how it goes.
if you have any problems finding a driver then give me a shout or
if you would rather i get you it
post back on here
hope this helps !!
Was this helpful?
Yes
No
Solution #2
posted on Nov 27, 2008
Very Helpful)
solargrl81
Rank: Apprentice
Rating: 100%, 2 votes
Hey guys,
So I've been working on this problem for a year now. The tilting thing making the connect/disconnect noise was awful. This is what I found out. Took the damn thing apart. Turns out that the wires that connect the orbicam to the internal port (which is near the power button, underneathe) were FAULTY!
When I moved the wires even just slightly, it made the noise, but when I kept them still, and touched the connections, it was fine.
So I took the wires out completely, with both connectors, ordered a new set (industry standard), installed them, and I no longer have the problem.
It would appear that Acer used **** wires or didn't assemble them properly in the first place, because too many folks are having this problem. Even with the Orbicam ceasing to work after only a short time. I assume it's the same issue.
GOOD LUCK !!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Feb 02, 2008
Not Rated)
ComputerDave
Rank: Guru  Acer Expert
Rating: 88%, 416 votes
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5100 PC Notebook
Questions and Unsolved Problems for Acer Aspire 5100 PC Notebook
Do you recommend Acer Aspire 5100 PC Notebook?
Answer
Answer
my acer 5100 laptop heats up and sometimes gets too hot. what's wrong with it? How can I fix it.
Answer
acer aspire 5100-3583 "black screen" after changing the ink cartridge on the attached... (More)
Answer
acer laptop aspire 5100, keyboard,all 3 USB ports, touchpad all inoperative.Unit booted up normally... (More)
Answer
My wireless connection worked fine up until today...I have reset the switch on the front of my Acer... (More)
Answer
Compaq laptop: my mouse pointer or arrow is frozen. It happened when I was using email. On the... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Van Nuys, CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
