On the wash cycle the agitator in the middle is turning in only 1 direction. When it is meant to be going in the other direction, you can just hear a clicking sound.
    Top Expert:
  • Washing Mach... Master
  • 46,529 Answers
Check for a broken attachment under the washer above the drive belt or a failed solenoid that engages the attachment.
Posted on Apr 07, 2015
Motor on wash cycle does not spim
??? wash cycle is not suppose to spin only agitate, most machine have a dual motor function, motor runs in 1 direction for wash then in another direction for spin. do u mean it does not go into spin? if so need to check the tranny and the clutch, the motor coupler in some cases and if its not agitating washing may have bad cam dogs in agitator, or bad water pressure switch, some times a bad door switch will not allow spin or agitation?
Sep 27, 2014 | Whirlpool Cabrio WTW6200VW 4.5 Cu. Ft. Top...
Agitator only turns in one direction
Check the motor/transmission drive coupler for wear
Feb 20, 2014 | Washing Machines
Limited agitation during wash cycle Load Sense OK
Possible that the program selected is an easy wash as this is meant for daily wash , less soiled clothes.
If however the same situation is present in all the cycles then the capacitor to the motor must be checked as it can reduce the speed of the motor.
Also check the belt , check for friction on the drum spindle and the motor.
Jul 22, 2011 | LG WT5001CW Washer
Simpson eziset 750. During the wash cycle, it does not agitate in both directions, it will only turn in one direction, then stop and pause like it wants to turn in the opposite dirction, then turns in...
Hi just read your posting.Depending on how old your machine is it could be a couple of reasons.1st thing I need to know is how old your machine is? Also when the machine should turn the opposite direction listen carefully and do you hear a hum from the motor when it should be turning in the opposite direction?Please reply with this additional information and I am sure I can help you .Looking forward to your reply.
Oct 14, 2010 | Washing Machines
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Washing machine won't agitate. It spins but does not agitate in the wash cycle. The agitator turns freely when manually turned. How can I repair this?
you will need agitator dogs if it is a whirlpool product you will need to open up the top cap on agitator there will be a 7/16 nut remove it and then pull from under bottom of agitator carfull it may pull off hard .After that the agiator splits in 2 in the middle there willbe 3 dogs in there seeded around the part insert new parts line up the 2 parts put back on and away you go .That is of course it is a whirlpoll product.
May 13, 2009 | Washing Machines
Maytag washer will not agitate. model pavt244aww
TURN THE PULLEY ON THE BOTTOM. ONE DIRECTION WILL CAUSE THE PULLEY TO TRAVEL UP AND RELEASE THE BRAKE, CAUSING THE TUB TO SPIN. TURN IT THE OTHER WAY AND THAT SHOULD BE YOUR AGITATION. YOU SHOULD HEAR THE TRANSMISSION CLUNK AS THE GEARING CHANGES DIRECTION TO GE THE AGITATION ARC. IF NO NOISE IS HEARD, YOU HAVE AN INTERNAL PROBLEM WITH THE TRANSMISSION.
Jan 25, 2009 | Maytag PYE2300AY Electric Dryer
Agitator and spin cycle
if you hold onto the top of the agitator stopping it from turning, and turn the "blades" at the bottom, does it make a ratcheting, clicky sound when you turn them opposite direction from each other
Oct 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will fill but won't "wash"
what kind of click are you hearing like a timer advancing or a hum them a click about every 10 minutes and dont rate me yet till were done
Jan 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
