Question about Siemens Dryers
What would make our siemens ultra sense electric dryer stop running after about 5 to 10 minutes?
I took the dryer all apart and cleaned any and all lint out of it,including the tub.The dryer started out not heating very well anymore and later come to find out we were not getting the proper power to the dryer because of a bad barrel fuse not making good contact.Once that was fixed were started getting good heat again,but know we cant keep it running long enough to properly get the clothes dried.When a friend of our was checking volts and ohms at the power cord connection,he touch his probes from his meter on the wrong contacts and got a big spark.Could he have shorted or blown something on the circuit board,or could it be a heat sensor.We do get the lint filter light flashing when it shut off.Thanx for any and all help.
  • Siemens Master
  • 5,323 Answers
I SUSPECT YOU SHOULD CHECK UR MOISTER SENSOR LOCATED IN THE DOOR OF DRYER.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Posted on Apr 13, 2015
What is causing my electric dryer to stop running after 5-10 minutes
I presume that after it has "cooled" it starts and runs again? If so, the air circulation, perhaps the vent is clogged and needs cleaning. The high heat protection device is "cutting out" when the temperature gets too high to prevent disasters.
Apr 10, 2015 | Siemens WTXD5300US Electric Dryer
Siemens ultra sense dryer stopped working, found broken belt, replaced belt but dryer still won't run!
-There are couple things that cause a dryer not working:
-Thermal fuse.
-Heater element.
-Timer switch.
-Door switch.
-start switch.
-Or the motor.
Check these components.
Good Luck
Mai
Dec 05, 2013 | Kenmore Elite HE4 Electric Dryer
I have a siemens ultra sense dryer and has started to show a code E01 I have checked the hose and cleaned the lint out I always clean the lint filter what next. It automatically shuts off and sends that...
This means there is an air flow issue most likely. Try running the dryer without the vent connected. If the dryer runs, the vent needs to be cleaned in the wall. If the dryer still does not, the thermistor on the front bulkhead will probably need to be cleaned or replaced.
Apr 13, 2011 | Dryers
Maytag Neptune Dryer runs for about 10 minutes and then stops. If we hit the start button it will run for another 10 minutes. It heats up fine while it is running. When this started we smelled something...
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Dec 26, 2010 | Maytag PYE2300AY Electric Dryer
Dryer stops after a few minutes Siemens WTXL2101 EU/07
Maybe a sensor at the back sensed overheating. You might be able to remove the backplate and search for a little button, which acts as some sort of reset button. (I do have a different tumble dryer, but it's the same brand and had similar problems). Maybe more ventilation is needed to prevent this from happening again.
Mar 28, 2009 | Siemens WT79020EU Electric Dryer
Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Feb 08, 2009 | Kenmore 62602 Electric Dryer
Time skips from 18 minutes to 6 minutes on automatic mode
It is the moisture sensor system, it is not sensing the wet clothes. Open the door, inside you should see a part with 2 metal bars that is around 3 inches long, clean these bars with a mult purpose cleaner. Sometimes fabric softner sheets and detergent builds up on this so that the machine cannot sense the moisture. Hope this helps.
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
E-1 light
check owners manual should have a code listing. Have you checked the vent and venting
Oct 17, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
158 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
