Question about Nordic Track Exercise & Fitness
I have an exp 1000 and during a workout the belt stopped and the machine started to beep and motor is hot. Can this be fixed?
    New Friend:
  • 41 Answers
Most likely you need to replace the motor and MCB. I might have these parts in my shop. Also check to see if the front and rear rollers are moving freely by disconnecting the drive belt. Shoot me a email at Elitefitnessrepair@gmail.com for parts
Posted on Apr 09, 2015
Stopped in Belt had been slipping smelled hot but motor was barely warm. Was 30 minutes into workout and machine stopped. Electric panel works but motor won't run.tilt works
time to lube the DECK belt, use WD-40 or grease. do it by each weeks. Try to loose the deck belt. in the way that you lift the belt by 2" with your finger. Otherwise, you must replace the belt+deck. See if the belt drive is to tight. And take time for maintenance the motor, replace the carbon brush+and lube the bearing.
Feb 08, 2015 | Nordic Track Nordictrack C1900 Treadmill...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
Nordictrack EXP 1000 belt runs but stops when I get on it. Drive belts are tight
1) Try to loose a little the drive belt, for to avoid a higher tension.
2) LUBE very well the deck belt, must shure is worn, proceed with the instruction manual maintenance.
3) Test the input voltage motor, if there are voltage the motor need repair
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faultyl.
See my personal TIPS for HELP.
Try to RUN THE software calibration for diagnose, and troubleshooting
sincerely. God bless you
Apr 24, 2012 | Nordic Track Nordictrack Exp 1000...
Nordictrack exp 1000 trips safety and stops abruptly...
Inspect belt and deck. The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. Continued use of your treadmill may damage expensive electrical components. 85% of all Treadmill problems are cause by worn belt and deck I would revisit the scene of the crime again.
Jun 10, 2010 | Nordic Track Exercise & Fitness
EXP 1000 starts and stops after about 7 minutes. Irregular speed changes during work out speeding up and then stopping. Thanks, Bill Hutton
I am not familiar with this model but it sounds like a speed sensor error.
Try un plugging treadmill, removing front cover and cleaning motor compartment paying special attention to motor and fly wheel. If that does not fix it may be a problem with speed sensor or circuit board.
Feb 07, 2010 | Nautilus Exercise & Fitness
My NordicTrack EXP 1000 stops in the middle of a workout. Before it stops, I smell a rubber smell. 1) Does the tread need lubrication? 2) Is the motoer burning out?
my nordic track 1000 stops several times during the workout. I can step to the side and the belt may or may not start back up. The display continues to display the set machine. any suggestions?
Jan 03, 2010 | Nordic Track NordicTrack Treadmill, A2550
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
171 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
