Question about Kenmore Washing Machines
Does my Kenmore 400 top loading washer have a drive belt?
    Top Expert:
  • Kenmore Master
  • 50,033 Answers
Tip it back a bit and look underneath
normally it would have as there is not enough space to have the motor direct drive.
Posted on Apr 07, 2015
My washer doesnt twist black and force
sounds like you have a belt broken that moves the drum...replace and should be ok...
Nov 27, 2014 | Kenmore 2942 400 3.2 cu. ft. Top Load...
How do you install belt
usually direct drive if top load,no belt has a motor coupling,send model number so i can look up your model,sears kenmore doesn't make washers,they just put the name on it,say washer starts with 110. on model,then you know whirlpool made it.
Jun 24, 2014 | Kenmore 24032\24036 Top Load Washer
Instructions on how to install a belt on a kenmore top load washing machine model #: 110.24622300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following illustrated description of how to replace a belt on top load washers:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=2d35143b9424efb2825c26899392c2e1
Sep 08, 2010 | Kenmore 22422 Top Load Washer
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
How do i change the drive belt
This assumes that you have a Whirlpool / Kenmore / Roper top load, belt drive machine.
See the following.
Apr 04, 2010 | Kenmore 24032\24036 Top Load Washer
How do i know if my washer has a belt
If this is a Kenmore top loader resembling the one you posted this question under, it does not use a belt. Kenmore washers are manufactured by Whirlpool. They use a motor coupling in place of the drive belt. It couples the drive motor to the gearcase (transmission). This configuration is known as a direct drive system. For future reference you should include a MODEL NUMBER when posting your question, so I can confirm how the washer is configured. If you need further assistance, please let me know. I hope this helps you.
Feb 15, 2010 | Kenmore 24032\24036 Top Load Washer
Hey bud, i replaced my kenmore washer with a new coupler, but still it will not spin??
inspect under the washer. look at springs for broken or one that may have come loose. inspect drive belt for broken or off pulleys. the drive belt is not turning pulleys, belt maybe broke or outa pulley grooves. or belt tension springs are broken or unhooked. good luck!!
Jan 09, 2010 | Kenmore 24032\24036 Top Load Washer
I need to replace belt on kenmore heavy duty washer, do I have to remove drive unit?
MOST NEWER KENMORE WASHERS ARE DIRECT DRIVE AND HAVE NO BELT,THEY HAVE A COUPLER BEWEEN THE MOTOR AND TRANS,LET ME KNOW IF THIS IS THE CASE WITH YOURS-MIKE
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator moves slowly
* Inspect the agitator
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
* Inspect the pump coupling
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
