Question about Building Materials
I hav a gdo6v3 it goes on the one direction and you need to press and hold the remote button how do l fix this
    Top Expert:
  • 10,875 Answers
One of the sensors are blocked or dirty,check all safety sensors or call for service
Posted on Apr 07, 2015
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
Have an old one for all remote 3220 need to know2 how to use the remote to scan for the code
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Aug 19, 2012 | One For All Televison & Video
Will this remote control a digital converter
Do a code search method to check whether the remote control can be used with your device.
Code Search
Jun 27, 2012 | Universal Remote Control Remote Control
How to use universal remote
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
Apr 22, 2012 | Televison & Video
I need to know what button is set
Direct Code Entry
    Code Search Method
Mar 22, 2012 | One For All URC-3021 Remote Control
Universal remote need a code ? or a remote
Hello
Universal remote code for Prima TV are :-
1019 0165 0116 0167
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
OK
Jan 19, 2011 | Prima C2012 TV
Hi i hav a classic irc 81082 universal remote controler for my tv. how do i programe it to my tv
If its the same as for a IRC81600:
1. Hold down the TV/Tuner Button.
2. Whilst holding down the TV/Tuner Button, enter the four character numeric device code.
3. Press any other button on the remote.
Aug 29, 2010 | Televison & Video
Alarm goes off when trying to remote start my o 06 malibu was up!!!
i hav same problem chaged battery noticed battery holder was loose so i soldered it very carefully everything works fine xcept remote start alarm just goes off like when you push the panic button not sure what happened dont think i shorted out the circuit board in the fob if engine light is on this car wont start via remote these remotes must b progamed by dealer or pro shop prob using what they call a tech II computer to remote start you hav to press lock button 1st even if car is already locked i figured this out pess and hold lock button then press start alarm dont ring and the car starts.
Jan 13, 2010 | 2005 Chevrolet Malibu
Pansat 2700A- V-hold
press "MENU" on remote, then press button directly below the "OK" button on remote 3 times to highlight "USER SETUP", then press the "OK" button on remote, then press the button directly under "OK" button 2 times on remote to highlight "TV TYPE" , then press left or right button directly beside "OK" button on remote to change it to "NTSC" .
Short version:
  • "MENU"
  • "USER SETUP"
  • "TV TYPE" , Change to "NTSC"
Dec 31, 2008 | Universal Remote Control 2700A DTV...
Building Materials Logo
50 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
