Question about Whirlpool Washing Machines
Whirlpool ultimate care ii dryer timer doesn't work. It'll run until you open the door. Help!!
  • Whirlpool Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Posted on Apr 13, 2015
  • 262 Answers
SOURCE: Whirlpool Ultimate Care II washing maching but will not spin.
lid switch is bad chance are you can by pass this by removing the timer header and crossing the outer wire on the lid switch that it mounted closest to the lid not the power cord this will tell you if you need a switch
Posted on Dec 03, 2007
  • 351 Answers
SOURCE: Whirlpool Ultimate Care II Timer is Off
possible timer fault does it spin
Posted on Mar 09, 2008
mikedurland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
  • 32 Answers
SOURCE: whirlpool ultimate care II dryer will not dry
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Posted on Jun 03, 2009
buffalonyman
  • 1865 Answers
SOURCE: My Whirlpool ultimate care II dryer stopped
You have to use a multimeter and troubleshoot the problem by testing the components in the heating circuit
Posted on Jul 23, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool Ultimate Care II gas dryer won't turn off.
    Dryer Won't Stop Running
    • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
    • If you need a new timer the best place ti get it is from Rough River Appliance Repair
    • Phone number is (270) 230-1818 his name is Charlie and he is the best!
    Nov 16, 2011 | Dryers
    Whirlpool Ultimate Care II Dryer timer knob
    The timer cam is not aligning the internal switches. Replacing it is the only fix.
    Eric
    Sep 17, 2009 | Kenmore 62602 Electric Dryer
    Whirlpool Ultimate Care II Quiet Dry I, LEQ9508PWO
    I would suspect the timer is on it's way out the door. Do you have any areas the timer has dead spots? Check the exhaust for any plugging also.Is this only on a first time start up or is it after this dryer has been running? If after running it could be a high temp sensor, that by the time you are playing around with it, the temp has changed.
    Jan 24, 2009 | Whirlpool LEQ9858P Electric Dryer
    Appliance rewiring wiring WIRLPOOL ULTIMATE CARE II
    The Whirlpool Ultimate Care II cannot be outfitted for a standard 115 VAC wall outlet. Your dryer is a 220 VAC appliance. It needs to have it own dedicated 30 amp, 220 VAC circuit with the proper outlet and power cord installed. The dryer heating circuits and timer will not run on 115 VAC. I think you need to reconsider what you are about to do...
    Jan 23, 2008 | Dryers
    Washing Machines Logo
    51 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
