Question about Shark Vacuums
My Shark steam vac rotator brush on the vacuum cleaner will not turn, belt isn't broke and nothing keeping it from rotating. What could be causing this ???? It is just over a year old.
  • 2,478 Answers
Call cust. service. They will tell how fix it or sent you a new head
Posted on Jul 05, 2015
Agent Don
  • 310 Answers
SOURCE: brushes do not rotate on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
Brushes do not rotate on
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 09, 2008
SOURCE: Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Posted on Sep 28, 2008
  • 5 Answers
SOURCE: Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Posted on Dec 14, 2008
SOURCE: DC 07 BRUSH BAR DOES NOT TURN BELT OK
Stand vacuum up and with it plugged in. Rotate knob between carpet and bare floor and back 5 times leaving it on carpet when finished. Rotate vacuum back from upright position and lay vacuum on the floor, rotating it onto its side. Turn vacuum on.
Posted on Dec 23, 2008
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac scrubbing brushes won't rotate -
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this problem.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on front, and 2 in the rear. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose *(one with a spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic pole has not broken.
If the pole is broken, you will simply need to replace the brush block assembly. The model F5914-900 uses Hoover 5 Brush SpinScrub Brush Block Part # 48437022.
Here's a direct link to this part on our GoVacuum.com storefront:
http://www.govacuum.com/hoovsteambru.html
If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Step on the handle release pedal so the SteamVac handle is lowered, and not in the upright position, as there is an internal switch that turns the brushes off when the machine is in the upright position. Now look inside the machine where the pole goes in. There is a green, square shaped female receptacle. This is actually the internal turbine that spins the brush block. Make sure that the switch for the brushes on the top of the machine is turned to "Rotating Brush Speed Hi". Turn the machine on.
If you saw the female receptacle where the brush pole is inserted was spinning, then your turbine is fine. If this part is not spinning, then you will need to replace your turbine.
I hope this helps you with your problem. Please feel free request a clarification request form here on Fixya if you have any questions, I'm always happy to answer follow up questions you might have. If you found this repair helpful, please be sure to rate it helpful by clicking the thumbs up icon. Thank you.
Chris J.
GoVacuum
Posted on Apr 04, 2010
Brush is not spinning on the pet hair power brush
Those things work off of suction, which spins a cog wheel that rotates and spins brush via a small belt. Disassemble the brush and check belt. Make sure the apparatus is clean and free of debris
Jul 25, 2015 | Euro-Pro Shark SC-505 Handheld Steam...
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Why won't shark cordless stick vac motorized brush work?
Is the brush rotating, if not the belt is broken or jammed, if so remove the bottom plate and all will be reveiled.
Oct 17, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
How to change a belt on a shark v15z vac. tks john t
John -
Your vacuum doesn't have a belt - only vacuums with rotating brushes use drive belts.
What problem are you having - why do you think you need to change the belt?
Please rate my solution if you find it helpful.
Oct 14, 2010 | Euro-Pro HEPA Shark EP035 Bagless Handheld...
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Steam vac hoover F7458900
There is no belt, the brush block is turned by a turbine. Check the brush block, make sure that the shaft that goes into the turbine isn't broke off, If ok, then replace the turbine, or take it apart and clean it out.
Jun 08, 2008 | Vacuums
Hoover Steam VAc carpet Model F7425-900
Take out the brush block, make sure that the shaft is ok, it goes up into the turbine, which is what drives the brushes. If the shaft is ok, then the turbine either needs to be cleaned and lubed, or replaced.
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes do not rotate
The brushs are driven by a turbine, if not turning, it may be bad. You can take it apart and try to clean it out, or just replace it. Also pull out the brush block and see if the shaft that goes up into the turbine is broken off, itis broke, then replace the brush block.
May 06, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Brushes do not rotate on Hoover steam-vac upright
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Vacuums Logo
302 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
