Question about Echo Garden
Echo CS-400 chainsaw is it better to clean or replace the gaskets in the carburetor. .saw won't start?
    Top Expert:
  • Echo Master
  • 10,875 Answers
Replace,ethanol in the fuel eats rubber,try to use gas without ethanol
Echo CS-400 chainsaw is it better to clean or repl - 6119df52-0f5d-4ab1-ba8d-bb93ea627f4f.png
Posted on Apr 07, 2015
  • 13 more comments
  • Love Joy
    Love Joy Apr 07, 2015
    Replace the carburetor for a new one?
  • Love Joy
    Replace the carburetor for a new one? I apologize replace the gaskets right?
  •  johnny rebel
    johnny rebel Apr 07, 2015
    carbs are 12 bucks,do you really want to rebuild the carb??
  • Love Joy
    12 bucks where? I saw one for $98
  • Love Joy
    I have an Echo CS-400 chainsaw and the carb is an 820A
  •  johnny rebel
    carbs for weed eaters are the same,that is why i gave pics,most any 50 cc carb will fit on and run any 50 cc motor or 45 cc motor,etc,they all have the same mounts
  •  johnny rebel
    http://www.ebay.com/itm/ECHO-CS-400-CHAI...
  •  johnny rebel
    look at them,they are the same
  •  johnny rebel
    http://www.ebay.com/itm/ECHO-CS3000-carb...
  •  johnny rebel
    http://www.ebay.com/itm/Carb-Kit-for-Ech...
  •  johnny rebel
    john mckinney,the part number you listed was for a primer bulb,also,do you make money off that site?? you are trying to get rich off this customer by listing those prices.
  • Love Joy
    I did. the one with box 2789Q is exactly like the one on my saw with and vent on top
  • Love Joy
  • Love Joy
    Thanks!
  •  johnny rebel
    yw,most people think that the only way to ensure they get the right part is to order original equipment,when there are cheaper ways to go about it,especially with carbs.
  • Echo Master
  • 1,169 Answers
First make the carburetor is your problem by adding a little fuel in carburetor throat and cranking. If the engine starts for a short time then most likely the carburetor but it doesn't then there is another problem.
Once you determine that the carburetor is the source of the starting problem. An good ultrasonic cleaning of the carburetor, replacement of the gaskets and diaphragms, and adjustment of the metering lever and fuel mixtures should get you running again.
  • 42 Answers
SOURCE: I have a broken primer bulb for an Echo CS-3400
You should be able to get to it if you just take off the cover that surrounds it. If you do not yet have a bulb purchased, I would reccomend trying the site I have below. I have also put the part number you will need to enter in the 'Search' box on the site to get the right bulb.
web site: www.m-and-d.com
Part #: ST-615-811
Posted on Mar 07, 2009
  • 63 Answers
SOURCE: Echo cs-341 stalls out when cutting sideways
Make sure the fuel filter is indeed attached to the fuel line in the tank and pushed down to the bottom of the tank.
Posted on Mar 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Chainsaw starts fine, but dies mid cut?
Immediately after saw quits, while everything is still hot. Sometimes ignition modules quit working when hot.
Ignition Coil Test
SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Loosen fuel cap when it starts to die, If that fixes it it has a fuel vent problem.
If you did nothing to the carburetor adjustments, are using a fresh (3 months or less) fuel mix with the same oil/fuel ratio, and are operating at the same elevation there is a reason your saw is acting up.
It sounds as though there may be a fuel delivery problem. Check the fuel filter on the free end of a hose in fuel tank (manufacturer recommends an annual replacement). Check all fuel delivery lines especially at fittings and bends for cracks and holes. If those are good then the likely cause is internal parts of the carburetor. HTH
Lou
Posted on Oct 12, 2009
dontbother10
  • 2220 Answers
SOURCE: i have an echo chainsaw cs 346 it starts fine revs
Try rotating the "H" adjustment CCW a small amount.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Posted on Jan 11, 2010
  • 277 Answers
SOURCE: how do I replace the purge pump on thr Echo chain
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Posted on Jun 21, 2010
Adjust the throttle on my echo cs305 chainsaw
Toni,
Can you give me a little more information on your problem. Are you having a problem with the throttle linkage or is it a carburetor adjustment question?
Dec 31, 2014 | Echo Cs305 Cs 305 Carburetor Intake &...
Echo Chainsaw keeps cutting off
does it start and run for a min or two then die try and remove the muffler and run it if ok open the muffler and clean the screen off
May 25, 2012 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Idle to high
Make sure the carburetor was re-installed correctly as any air leak between the carburetor and cylinder will cause high engine speeds but almost no power. It can also scuff the piston/ring(s) and cylinder due to very lean lubrication from the fuel. Hope this helps!
Jul 12, 2010 | Echo CS400 18" Chain Saw
What are the adjustments for the high and low mixture screws on the carbureator? the carbureator is from an echo 500vl chainsaw.
Echo thinks your actual model number is CS-550EVL. Page 14 lists the starting points for carburetor adjustment here:
http://www.echo-usa.com/pdf/documentation/CS550evle_010186.pdf
Additional manuals for you saw can be found here:
EchoUSA
http://www.echo-usa.com/documentation.asp
More choices can be found by typing CS in the model: window then clicking “Search”.
Once initialized this is the best procedure I have found.
Lou
Feb 13, 2010 | Garden
I have an echo chainsaw cs 346 it starts fine revs fine but chokes out when under load if i faether the throttle kinda helps cleaned the carb no different any suggestions
Lou
Jan 07, 2010 | Echo Garden
Ignition Coil Test
SmallEng.com
Lou
Oct 12, 2009 | Echo Garden
Garden Logo
123 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
