Brown marks on washin after the spin cycle
I regularly clean my machine but now clothes are coming out with brown marks on them. Even the hand washing that is put through the spin cycle only.
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
There is rust inside the tub that you cant see.if it is new,contact the manufaturer if it is old,,,get a new tub or washer
Posted on Apr 07, 2015
My clothes are coming out with brown marks, even if it is just hand washing being spun only.
you may have to remove the agitator and clean out the mud from under it
It may be a failed seal on the shaft and the gear box oil is being forced up the shaft and into the cloths.
The mud is from washing powder ( basic clay) that will not properly dissolve or be removed when the empty cycle is operating
If that is the case change over to liquid detergents
Apr 07, 2015 | Washing Machines
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Even after doing the spin only cycle, my clothes
Is drum spinning on spin, check belt tension if not. if this is ok then it could be problem with motor brushes, or if it is induction motor it could be a capasitor
Feb 08, 2010 | Washing Machines
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Jun 18, 2009 | AEG Lavamat 88840 Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Door unlocks and won't spin or drain
it sounds like a clogged filter
Please remove the filter on the side of the machine or the front.
Make sure you have towels handy.
Clear the filter out. If your pump cant empty the machine out you will get these problems
Make sure waterline is not obstructed
Apr 15, 2008 | GE WSXH208A Front Load Washer
Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
