Question about Coby 20" Flat Screen TFT LCD TV Monitor
Samsung Monitor Model : LS198300NS giving distortion on screen, when I change it with Sony Laptop cable, it becomes ok, but not with a Samsung Cable. What should I do ?
Email : jitups@yahoo.com,
  • 93 Answers
Hi
if you monitor is old , it may be due to bad filter caps in the power supply section!
if its not that old then the cable is itself at fault!
Posted on Apr 07, 2015
Started getting distortion on screen. If I use Sony laptop power cable it becomes ok, but if I change with a new Samsung cable, again distortion
All cables are not created equal. The new cable simply does not meet the requirements of your system. That is so if the cable is placed exactly in the same position as the older cable and attached the same way. Just why that is so is probably an engineering question related to the specifications of the two cables. (Some cabling is shielded, reducing the electromagnetic field that may be generated around a cable. Historically, that field could distort monitor screens.)
Apr 07, 2015 | Samsung Computers & Internet
Half black screen with white lines
check the display on external monitor, if its ok , then its fault of either the display cable that gives display to the lcd of laptop or the screen becomes faulty
Feb 07, 2013 | Toshiba Satellite A105 Notebook
What's your problem?On going problems with Samsung R519 laptop after all the advise I tested laptop on separate monitor and it worked fine with no problems I bought new screen lead and still had p
The external monitor has proven there is no problem with the video graphics card, I'am concerned that customers have complained about faulty screens.
I have changed a lot of displays without issue, there is a major circuit board mounted behind the screen that plays a roll in picture production so if something goes wrong you get all kinds of symptoms from fuzzy images to multi color lines to a blank screen. I would suggest getting your money back because of his track record, also go online to Samsung and contact customer support and the technical department to see if something was over looked. Question! is this a new or used LCD display?
Apr 06, 2012 | Samsung R519-53S Notebook
My monitor screen has become greenish and with
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
Dec 17, 2009 | LG Flatron L1750S 17" LCD Monitor
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the problem.it seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
Screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Dec 02, 2008 | Computers & Internet
Colour distorted after laptop fell
its better you should take it to the technician, i think the cable that gives signal to the panel has become faulty
Nov 24, 2008 | Acer Aspire 5610 Notebook
Screen Distortion at certain Refresh Rates
Have you connected the laptop to another monitor and use the same refresh rates that cause the distortion? If the distortion appears on a different monitor, then I would have your laptop examined by a pc engineer, but, if the distortion only appears on the 997DF monitor, I suggest having the monitor checked at a repair shop, also, have you tried connecting the 997DF to a desktop PC, and use the same refresh rates?
Jun 16, 2007 | Samsung 997DF 19" CRT Monitor
940mw - Compatibility
First thing i would check is your settings. See if windows is reconizing two monitors. If not then you will need to tell it to find it. Hook up your second monitor goto add new hardware and see if windows finds it. If it doesnt find it then i would go to manufactures site for your laptop and see if there are advanced drivers for that particular model of monitor.Also I would look at the manufacures site for advanced settings or technical information. This should solve your problem.
Nov 14, 2006 | Samsung SyncMaster 940MW 19" LCD Monitor
Coby 20" Flat Screen TFT LCD TV Monitor Logo
54 people viewed this question
Top Coby Computers & Internet Experts
shadowchb
Terry Hair
Are you a Coby Computer and Internet Expert? Answer questions, earn points and help others
