Question about Weedeater Featherlite Gas Blower, 23cc - POULAN/WEED EATER
Weedeater featherlite fx265 xtreme wont,t keep running
Won't keep running
    Prodigy:
    An expert who has answered 500 questions.
  • 516 Answers
See attached check sheet
Posted on Dec 13, 2017
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 77 Answers
SOURCE: sears featherlite weedeater wont start
Needs carb rebuild kit and carb rebuild,likely its one of those carbs made in china.
Posted on Aug 17, 2009
  • 279 Answers
SOURCE: Weedeater Featherlite stalls out when running
Do you let it warm up? If you don't, let it. I start mine and let it run on half choke until warm then to run.
Posted on Jun 07, 2010
rycgl
  • 1545 Answers
SOURCE: I need a fuel line schematic for a WeedEater brand
Presuming the primer bulb is on top of the carb....Fuel filter line out of gas tank goes to the lower part if carburetor body. The other line (normally larger in size) coming out of the fuel tank goes to the primer bulb outlet on the top of carb.
If the primer/purge bulb is not on the carb, things are a little different. The fuel filter line out of the tank still goes directly to the carb, as the bulb will pull old fuel/air out of the carb allowing fresh fuel to flow in and pushes old fuel/air back to the fuel tank.
Fresh fuel in, old fuel out of the carb...you can hook up a piece of fuel line to the bulb and tell which one is pulling and which one is pushing..or depress it with your fingers on it...either way you can tell.
Posted on Jul 04, 2010
riceski
  • 1851 Answers
SOURCE: have a featherlite 25cc weedeater. can not get it
clean the carb - remove - clean and re-install it.
Gary @ Fix Ya
Posted on Jul 15, 2010
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
Starts but won't keep running then won't start
Check your Fuel Pressure and if that is good (over 40 psi)
then check your Idle Air Control (IAC) Valve
and seeing that it is a Mid-90's Chevy.. MAF Sensor is going bad.
If you UNPLUG your MAF and see what happens.... MAF is in the Air Intake with a 4 wire...
Apr 15, 2013 | 1994 Chevrolet Lumina
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
1994 evinrude boat motor keeps blowing fuse. motor keeps running but once shut off won't restart. also while motor is running the tilt won't work work
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 27, 2012 | Cars & Trucks
Fuse in motor keep blowing and motor keeps running but once stopped won't restart
What year, make model and engine size there? Send details please.
98 Expedition..5.4L 4WD..coded bank 1 bank 2....O2 sensors..LEAN....replaced both..no change..still same codes..now it won't stay running. Tried to code again..won't run long enough to get a c
all code readers will retrieve information stored while in the on position --doesnt need to be running ---when you rehook up scanner either resubmit or edit request with codes
Aug 15, 2017 | 1998 Ford Expedition
I have a craftsman eager-1 4.5 hp mowerthat won't stay running. If I hold the primer bulb in, it runs. I've adjusted the screw all the in and it still won't keep running. Any ideas?
Do you hold the primer in or pump it? Pumping the primer forces the fuel into the intake bypassing the diaphragm's intended function. Assuming you pump the primer to keep it running your carburetor is dirty and should be cleaned. Ensure that your fuel is fresh and that your fuel can and fuel tank has no water in it. Ethanol in fuel will evaporate and cause condensation thus creating unwanted water.
Apr 20, 2012 | Craftsman Garden
My jeep won't start unless I give it gas. It used
Did you clean the throttle body and plate of any carbon ?
Aug 27, 2017 | 1998 Jeep Grand Cherokee
Replaced ctm unit and truck won`t stay running.
there are 2 sensor on the carb . you may need to replace both to find out whiche one it is . try this also give it gas while starting and when it starts you will have to keep your foot on the gas a little to keep it running if it runs that way its one of the 2 senors .
Jan 20, 2009 | 1997 Dodge Dakota
Weedeater Featherlite Gas Blower, 23cc - POULAN/WEED EATER Logo
79 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
ray gallant
 steve
steve
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
