Question about InFocus SP-LAMP-LP9 Projector Lamp for LP925, LP93
How do I reset the lamp timer for the infocus LP925 projector? Are there other problems that could cause my issue?
Projector turns on, lamp lights for approx. 3 seconds, then shuts off. I have replaced the entire lamp module within the past two months. As per the Troubleshooting section of the manual: I have unplugged the projector, waited over an hour, removed the back cover, removed and replaced the lamp module, replaced the cover, and turned on the projector. Problem persists.
  • 93 Answers
Hi
this lamp has a small lamp pcb with a chip on it.
have u change the complete module or have just changed the bulb.
if you have just changed the bulb then u have to replace the small fuse on the chip.
this should help to reset the lamp timer!
Posted on Apr 07, 2015
The bulb dont turn on
Projector Lamp Life and Brightness - Projector Reviews
www.projectorreviews.com/articles-guides/lamp-life-and-brightness-2/
Feb 26, 2015 - There are still a number of 2000 hours at full power projector still on the... brighter, like projector Y, but Y just doesn't have the picture quality.".
Resetting Lamp Hours on a Sharp Projector - Spiceworks
https://community.spiceworks.com/.../2235-resetting-lamp-hours-on-a-sh...
Jun 12, 2011 - However, once you change the lamp the projector still won't turn on ...If it still doesn't work then there is some other problem with the projector.
How to Repair InFocus Projector Power Issue (LP290 ...
? 1:56
https://www.youtube.com/watch?v=sPGZSJXpxqI
May 7, 2012 - Uploaded by zibodiz
A common problem with older InFocus LCD Projectors causes them to turn off at ... How to Repair InFocus Projector PowerIssue (LP290/LP280) ... How to Install a Bare Projector Lamp into your Projector - Duration: 4:05. by ..
Dec 14, 2015 | Office Equipment & Supplies
Resetting the lamp timer on an infocus in24 projector
To reset the lamp timer on an in24 go to settings, then select Service. The option to reset lamp hours should be in this menu.
I hope this helps!
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 04, 2014 | InFocus Office Equipment & Supplies
Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Sep 25, 2009 | InFocus ScreenPlay 7200 Multimedia...
The tv shuts down and an orange light flashes
if it's the lamp led that is orange, turn off the projector for a minute and try it again. if the lamp goes out and the orange led comes on again, replace the lamp and reset the lamp timer.
Jul 25, 2009 | InFocus X10 DLP Front Projector 1080p DLP...
After a while the projector turns off and the amber light blinks
projector getting too hot (check filters), or lamp is dying (replace and reset lamp timer)
Jul 07, 2009 | InFocus LP 630 Multimedia Projector
The lamp warrning light on my infocus in24+
If you are able to measure/show any continuity whatsoever your bulb is way past bad!!
As these lamps do not have filaments.
If you have replaced the lamp you can easily reset the lamp timer from the projector menu.
This procedure can be found in the user manual as well.
Cheers
May 02, 2009 | InFocus Projector Lamp for IN24+, IN26+
Infocus LP350 won't show signal, also panel buttons don't light up
Hi LuckyLindy
Next time this happens , just take out the main connection to the Mainboard and plug it back in.
Also remember to reset your lamp timer now that you have replaced the lamp !
Apr 24, 2008 | InFocus LP350 Multimedia Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Projector will not fully startup
the colorwheel is bad. and what's worse, you can't get parts for the lp340 anymore.
Dec 01, 2007 | InFocus SP-LAMP-LP3F Projector Lamp for...
InFocus SP-LAMP-LP9 Projector Lamp for LP925, LP93 Logo
590 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
