Question about Sony Computers & Internet
I have a Sony pcg-961a I have lost the power cord is there any way to run it or charge it from my computer
  • Sony Master
  • 1,150 Answers
commanderzod
  • 112 Answers
SOURCE: Sony PCG-FX340K (PCG-993L) Laptop
Hi z14jc.
Clink on the link below
http://cid-ccc9919d689e8b4c.skydrive.live.com/browse.aspx/Public
Download the VAIO dissasembly.doc
Its not for your model but should be close enough.
I am presuming that your laptop is OUT of warranty and you have a good idea of what you are doing?
Ensure you have an ESD strap on when touching components.
Good luck.
Let me know if this was useful.
Posted on Feb 29, 2008
  • 10 Answers
SOURCE: sony vaio pcg-grt170 when I push the power button,
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Posted on Feb 18, 2009
venexcsd
  • 1185 Answers
SOURCE: Won't turn on even with power cord plugged in
By dumping the power while running you have trashed your Operating System or blown up the Ram
Insert your OS disk and see if it comes to life , if it does then you may have to try a repair from the OS installation CD
If you have popped the Ram then the only solution is to get it checked out on another PC
Posted on Jun 02, 2009
SOURCE: Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Posted on Oct 16, 2009
  • 3 Answers
SOURCE: I have a Sony viao PCG-7V2L and my battery and 110 power dont
Time to get a new battery for your Sony VAIO PCG-7V2L: http://www.laptoptraveller.com/battery-sony-vaio-pcg-7v2l-series-laptop-notebook-accessories.html
Posted on Dec 07, 2009
Sony pcg-7d2l will not turn on
Most likely either the power cord/charger for your computer needs to be replaced or the motherboard in your laptop died.
Jun 01, 2012 | Sony Vaio PCG-7D2L...
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
Vaio pcg671l lost external power (no problem for the power supply cord, work well wit battery). I am looking for a compatible docking station as external power instead.
hi
hi. I would like to suggest you get these parts are offline, because it's easy for you to test before buying {make sure you match the parts before buying}
regards
May 15, 2011 | Sony VAIO PCG-505 PCG-671L PCG-700...
Hi, I have a Sony PCG-791M that is completely dead
maybe it is your mains cord not getting any power to your laptop hence not being able to charge the battery hence no power at all have it checked and good luck.
Feb 21, 2010 | Sony Computers & Internet
My sony pcg-k23 screen will not turn on. the computer is running but no screen
the lcd may be broken or the connection cable may be loose. in both cases, if you're still on warranty coverage, ask for specialized help. if you're out of warranty coverage, then try to troubleshoot the problem with your user's manual. if you can't solve the problem this way, try opening your computer and check if the cable is loosen. be careful to remove the battery first and unplug the power cord before opening the laptop's chassis.
Feb 06, 2010 | Sony VAIO PCG-K23 Notebook
How do I charge a new laptop battery for a sony pcg-fx220? Do i leave the laptop on to charge, or shut down?
Plug the power supply into the back of the laptop
Switch the power on at the wall socket and go to bed.
The machine will take care of the rest
Jan 26, 2010 | Sony VAIO FX220 Notebook
Oct 16, 2009 | Sony VAIO FRV37 Notebook
No Power Sony Vaio PCG-394L
try this remove the battery the ac cord and the memory from the pc,(two screws on the backside where the letter m ison the botom).Hold the power button down for twenty seconds.This usually clears the settings.Put the nenory back in the battery back and try turning it on.
Good Luck
Aug 26, 2009 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
56 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
