Buttons are sticking - Televison & Video
    Top Expert:
  • 10,875 Answers
If you are savvy,you can take the remote apart and clean the button panel and front plastic
Posted on Apr 07, 2015
  • 1,150 Answers
Hi Pamela
Common problem
Hold remote upside down while cleaning with a damp cloth and tooth brush. Clean Cracks.... e.g. needle
Keep food and sticky stuff away from remote or any keyboard
  • Pamela Smith
    Pamela Smith Apr 08, 2015
    many thanks has helped
ROKU STICK IS NOT STARTING AUTOMATICALLY.
Check plug in roku stick and in electrical outlet for a good connection pull out and push back in..Their is a small reset button on ROKU,push it ,it will then show a blinking white light,if not you may have a bad roku stick.
Hook up ROKU stick BEFORE you put batteries in remote,after you put in batteries you will have to push button near batteries.
The remote should start blinking a green light this means it is trying to pair up with roku stick.If it does a purple sceen will appear on tv.Push home button remote and tv should give you a code.This code has to be entered at ROKU site link on computer.
Jan 29, 2016 | Roku Streaming Stick
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Need to format memory stick for Sony cyber shot DSC 750 camera...tell me how!
Hi the first thing you do to format your memory stick is you need to Insert the memory stick on the camera because it is formatted in the camera.On the camera,you need to turn the MODE DIAL to the SETUP position.And then turn on the camera. By using the CONTROL BUTTON, kindly press the DOWN ARROW button to select MEMORY STICK TOOL.And press the center of the CONTROL BUTTON.Kindly press the UP ARROW or DOWN ARROW button to select FORMAT.After that press the RIGHT ARROW button.Kindly press the UP ARROW or DOWN ARROW button to select OK and press the center of the CONTROL BUTTON.
Hopefully those instructions will help you get going again with your Sony digital camera. Good luck!
Apr 22, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
How to format my memory stick in sony Cyber shot DSC750
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
The memory stick cant even be reformatted or opened by the computer neither can the psp
If this is the case, and you appear to be savvy, then it is possible that the memory stick has failed. Also, check to see if there is a lock button on the stick. A lot of times, the memory stick will have a lock button on it.
If no lock button and no recognition, then Luke, the chip is bad.
Jan 23, 2011 | Video Game Consoles & Games
Gear stick stuck!
Are you pressing down on the brake padle when you are trying to get it out of park? If that don't work check the fuses & there may be a relay that's may be related to a safty divice to the stick shift. If you don't press the brake padle the stick shift will not release so if you leave the car running a child could not push in gear. The lock silinoid is at the gear console
Apr 24, 2009 | 1993 Volvo 240
Taking still photoes with the memory stick.
1. Set the mode switch to MEMORY STICK. 2. Set the power switch to CAMERA. 3. Press the PHOTO button and hold it. **If you do not wish to keep the still photo, wait 2 seconds until the picture releases. 4. To keep the image, pess the PHOTO button once again within 2 seconds after releasing the button. The still image is recorded to the Memory Stick. **Audio cannot be recorded onto the Memory Stick.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
