Question about NewAir Ai-210ss Portable Ice Maker - Easy To Use Ice Machine - Lightweight -
Portable ice maker won't fill.
It keeps cycling through the dump ice phase. Does this 2-3 times then just stops and the tray is not level. Never fills tray now. I'm thinking maybe the tray jumped a few teeth. I've seen times when ice would build up and block the tray sometimes.
How to get direct drain option to actually work on my Edgestar DEP700EW dehumidifier?
The outlet is probably clogged with moss or foriegn bodies. Clear the water way.
Sep 11, 2014 | EdgeStar 70 Pint Portable Energy Star...
Emtied water out of tray and machine will not strart lights are all on the top of the machine is their a reset button i did set the tray with a hose to empty by itself don't believe that would...
If the hose is still connected and it's not clogged, the water shouldn't have filled the bucket.But, let's get back to emptying the bucket and reinstalling it and the unit won't start.
Several things can cause the this. The first and most notable is the bucket is not installed properly. When that happens the bucket safety removal switch, does not make firm contact with the bucket when it's reinstalled. If the hose is still attached, temporarily remove it and reinstall the bucket so that it fits "squarely" from top to bottom into it's holder. Make sure that is makes firm contact with the bucket safety removal switch on the back wall of the bucket holder. When installed properly the bottom of the bucket should not tilt down at the bottom.
The second most notable thing, is that the humidity level in the room is the same as whet you have the unit set to extract. In this case, the unit won't turn ON, until the surrounding humidity level rises. To test this, lower the humidity extraction level to 32%. If the bucket is installed properly and the Air Intake Filter is clean, the unit should start.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 22, 2011 | Haier 65-Pint Dehumidifier
The 54701 Kenmore Dehumidifier runs and sounds normal, fan running, compressor on. However , it doesnt collect any water whether a hose is connected or just the bucket. No icing up or any weird noise...
Yes, if the compressor needs to be recharged, a service technician can do it.
In the meantime, try lowering the humidity extraction level to 35%. You may have the extraction level set to high.
Hope this helped you. Thanks for choosing FixYa.
Aug 21, 2011 | Kenmore 54701 Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
My kenmore 50 pint dehumidifier 54501 runs but it does not taking in water
You need to determine what's "running". Here's why: There are three things that must be working to extract water. The 'coil' (a finned metal part that needs air to flow across its surface) may be filled with dust and obstructions, so no air can move...then no water. There is a blower motor that must move the air. If it is seized up and not blowing air...very little or no water. The compressor creates condensation from air moving across the coil (like the moisture than forms on an ice filled glass on a humid day) to extract the water from the air. If it's not working then no water.
So, if there is air blowing out of the dehumidifier the blower is working. If the air is room temp the compressor is not working. If it's real hot air, and the humidifier keeps cycling on and off quickly, the coil is dirty. Those are the 3 things that need to be working.
Jul 18, 2009 | Kenmore 54501 Dehumidifier
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Fan fixed but evaporator solenoid keeps activating at times
the purpose of the valve is to de-ice the evaporator and the valve is turned on by a timer usually. in normal operation, the evaporator builds up with ice (that is how water is extracted). when the valve operates, to put it simply, the hot gas is routed to the evaporator and hence melts the ice off
Aug 28, 2008 | Goldstar DH504EL Dehumidifier
Coils Frost up and Bucket never fills
Poston192: You have a refrigerant leakeage in the unit, that's why it's frozen up. If you want to do it yourself, here's what to do: 1. Disconnect power from unit. 2. Remove covers from dehumidifier and locate coils and evaporator units inside. 3. Check for greasy or sticky signs on joints and weldings. 4. Once locate it, re-solder (in case of leakage on weldings) or adjust very tightly the joints. 5. Reassemble and test. SithPitt
Jul 04, 2007 | Kenmore 5245 Dehumidifier
NewAir Ai-210ss Portable Ice Maker - Easy To Use Ice Machine - Lightweight - Logo
94 people viewed this question
Top NewAir Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a NewAir Dehumidifier Expert? Answer questions, earn points and help others
