Question about Vehicle Parts & Accessories
How do you charge the unite . I have charge for more then 24 he's.
I have it , in the off position for more then 24hrs. An it has not fully charged
  • 774 Answers
Hi,you can also youse halfords,they will check the battery and alternater if you can get the car down to them.
Posted on Apr 16, 2015
    Scholar:
  • 123 Answers
How old is the battery? Batteries do ware out. Have you had it tested? You can get it tested at most Sears Auto stores for free. If you can take it out of the vehicle and take it to Sears, then you could save yourself some time and money. I am assuming that your battery charger is working correctly. Do you have it hooked up to the right terminals? When the unit is plugged in, does it make a low level humming noise (indicating that it is working)? Does a value register on the gauge?
Posted on Apr 07, 2015
Cant charge it Lights keep blinking and the only thing that works is the horn.
Before charging, make sure the unit is turned off. Connect the charger to the wall outlet first and then to the chair. Check that the battery cables are attached fully to the control box. Turn on charger. After charging, remove charger and verify the unit is fully in gear. The levers must be fully in the up position. If the lights still flash, some wiring is probably loose, or the drives are not fully engaged.
Jun 20, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Standby power does not work
The question is confusing. What did you replace the battery in, the battery back up power supply or the transmitter? The 300MC is just the transmitter and changing that battery has nothing to do with whether the main power unit will function if you unplug it. Now, if you replaced the large battery in the opener itself, it needs to fully charge before it will function properly so give it about 24 hours to charge with the power cord plugged in and then try again. It should work IF you attached the wires to the CORRECT terminals on the battery, positive to positive and negative to negative. If you did not, reverse them, allow the battery to charge 24 hours plugged in and try again. If you installed it in reverse there is a chance you fried the circuit board and that means you will not be able to use the backup feature although the opener may function normally without it.
Sep 14, 2014 | liftmaster Chamberlain Garage Door Opener...
How long does it take to recharge my oral b toothbrush and should it work when put on charger sraight away
The first time you use the unit, it should be charged for 24 hours or more.
When it needs charging, my unit takes over 24 hours to fully charge and then lasts around 14 days until it needs another charge.
Is this helpful?
Gary
Feb 28, 2011 | Vacuums
Just got the slicK mp418c-4, now my problem is, that it is not connecting to my computer in order to put anything on it. Can anyone help me with this?
Unless something is wrong with the unit you should be able to have the unit in the on position then plug the unit in to the computer using the USB cable for the machine. I would make sure the unit is fully charged. You will need to have the unit in the on position and plugged up to charge the unit fully.
Sep 22, 2010 | Audio Players & Recorders
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
New netbook keeps shutting off. its plugged in and charging.
the other trick wrap battery in a cloth then put in paper bag then a plastic bag put in freezer for 24 hours this will wipe the charge memory in battery.then leave at room temp for about 2 hours and recharge .try run laptop without batt,if it runs with shutting of the batt is dead.
dt
Dec 06, 2009 | Acer Aspire One PC Notebook
Archos 605 charging
Hi if the unit has been on charge that long it should be fully charged.
With charging supply connected what is the (CHG) green led doing. (on top of 605) Flashing---fully charged. Steady---charging.
(if this was helpfull please rate)
Dec 02, 2008 | Archos 605 WiFi Digital Media Player
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
