Question about Tview D65TSG 6.2" In-Dash Navigation
I installed a new gps micro sd card and pushed the gps button, but theres no gps display.Everything else works fine.The GPS title shows that it recognized the loaded card,but it will not load.
I bought a Garmin 600 GPS and a OnXMap Micro SD card for my state of Oregon. I can't get the GPS to recognize that it is even in the unit.
Plug the GPS into your ??, and put the Micro SD card in it and install it and see if that will help.
Sep 27, 2017 | Garmin GPS
Nuvi2555LMT
The micro SD card has to be between 4-8gb. Garmin Express is used to load the South American maps. Garmin Express can be downloaded from Garmin. Once installed on your PC, plug your GPS into your PC. The program should give you the option to install the South American maps to the SD card.
Dec 31, 2016 | Garmin nuvi2555lmt nuvi 2555lmt
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Micro sd card not showing up on the gps
Have you got GB Discoverer on the card? The map should appear on the Map Information list in the Setup > Map area. Double check the placement of the map card. Also, in case you have not found it yet, there's wealth of information on the Oregon Wiki here: garminoregon.wikispaces.com
Nov 02, 2009 | Garmin Oregon 550t Handheld GPS Receiver
GPS does not start up correctly
Ok, there should be a small hole located on the device, you need a pencil or little pin to press a tiny button inside. Hold it down for a few seconds and the device should reset.
Also on most GPS devices the maps are installed on the device itself, not the memory card. (usually used for music, etc) If it came with any software and this problem persists, I would suggest reinstalling it.
Hope this helps ya out! :)
May 28, 2009 | MyGuide 2350 GPS Receiver
When i start the lucca 3.3 mp3 it shows "upgrade sd card" and it locks up. I tried to reset but i only get this popup screen. Someone knows a cure?? thnx...
I had same trouble with my Lucca 3.4 and I resolved it.
1/ From "Lucca 3.4 GPS DVD" I copied all files from /Recovery  onto SD card
2/  With SD card inserted I started Lucca3.4 pushing 2 buttons (together)
  Switch ON/OFF and MENU, and he will reimage rom (took about 8min)
3/ when GPS auto-reboot-ed I pushed YES on screen and he started to upload
soft,files (took about 20min)
4/ after this I reinstalled maps from Lucca3.4 GPS DVD
Now my Lucca 3.4 works fine again !
BR
Dan
Feb 22, 2009 | Blaupunkt TravelPilot Lucca MP3
My tomtom doesnt turns on. It shows the green led when pressing the power button, but doesnt show anything. It doesnt charge and doesnt show any led while on charge. I tried the reset for 10 sec (and 15...
Remove the micro sd card from your TomTom. Look at the bottom of your unit, where the copper contacts are (where the unit mounts to the windshield mount). You will notice a "cut-out" in the plastic case, just above the contacts. The reset button is there. Use a paper clip and depress this button for 15 seconds. Now press the power button, and it should turn on. Now replace the sd card.
Jun 27, 2008 | Tomtom GO 510 GPS Receiver
Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
Voice won't work
Have you dtried reseting the GPS. Turn Off unit, take out SD card, at the back of the unit there is a tiny reset button push this with a end of a paperclip and then turn back on and re input the SD card this should return your voice.
Dec 13, 2007 | Tomtom GO 510 GPS Receiver
Tview D65TSG 6.2" In-Dash Navigation Logo
62 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
