Question about Radio Communications
I have a galaxy dx 99v2 18 ft coax hooked directly to ball on my 102 wip and spring ,3ft jumper to swr meater all grounded to battery and power directly to battery tryed to set SWR and pegeing out
I also have polamar 250 hd liner not hooked up yet ,,all wiring to battery is 8 gadge and grounded to battery an boddy cant get swr set galaxydx 99v2 is a non callabreat moddle what can I do
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
First of you have to set the SWR on the radio first . then some liniers require you to run low wattage and others high wattage . the SWR is what you have to control by keeping it low . You must take into consideration the length of the coax plus any jumpers you have . You say you have 18 ft of coax plus a 3 ft. jumper ,thats 21 ft..You should keep that jumper as short as possible ,like 12" . plus you should make sure the antenna is grounded good , like to a good spot under the vehicle . 102 " whips are supposed to be almost perfectly tuned for a good match .
Posted on Apr 15, 2015
One Wire
  • 126 Answers
SOURCE: galaxy dx 77 hml
The closest radio I have on hand to that one is a
Galaxy 33HML
If looking at the front of the meter, this radiois wired:
black and red wires soldered to gether on the left post
purple wire on the right post.
I hope this will help.
Dean
Rollin CBs
Posted on Jan 26, 2008
Shuttle83
  • 1139 Answers
SOURCE: CB transmission
Hello 64driver,
Make sure the radio is grounded properly and that the SWR is around 1.2:1, 1.3:1 is good but try to get it to 1.2:1. Also take a power output reading while keying the mic. To do this with your power meter put it in-line with the CB and your antenna and key the mic you should get about 4 to 5 watts PEP. If this is the case your unit is putting out the proper power level, if not have the power amplifier checked by a qualified repair shop.
I hope this helps
Shuttle83
Posted on May 14, 2008
  • 773 Answers
SOURCE: refurbished dx 959 from galaxy no modulation? no transmitt?
If there is no transmit at all, it sounds like it wasn't fully refurbished. If it is just low modulation then just turn VR16 and VR14 all the way to the left.
If its not working at all, send it back. It hasn't been refurbished.
Posted on May 03, 2009
  • 1274 Answers
SOURCE: power meter on my dx-979 barely moves off of 0
Well,some meters are set different than others,to see what is going on,you need a good WATT-SWR meter,but that is not a bad reading of SWR, you can get one at Radio Shack. You can not go by the meter that is on the radio,it,s probably not set right. hope this helps..
Posted on Mar 21, 2010
  • 5 Answers
SOURCE: I can't get the swr value close to 1 it's over 3 what am i mising
Several things are working against you.
1 Antenna location= Needs to be in CENTER of car or truck, and high. no grounded metal can be next to the element (the hot/positve part of the antenna)
2 the only way to really ground the antenna is by having a flat metal ground plane under the antenna. DC grounding does NOT do this, that is a misunderstanding.
3 make sure you use a tunable antenna. I have found the wilson's to be very easy to tune and performe very well, for a base loaded antenna.
4 in short a wilson or k40 magnet mount placed on the very top of the roof in the center will have a perfect ground plane. Then shorten or lengthen the steel whip to ajust your SWR's. You will get the best results this way. This is the ONLY way to achevie good performace.
5 I will say this the absoulte best antenna is the 102"steel whip, if you got the clearnce and dont mind it hitting tree limbs put it on a big magnet mount with a spring at the base and youll have a perfect antenna. But the wilson is shorter and easier to tune.
Posted on May 16, 2010
Help...Extremely high swrs. Galaxy dx 44v twin tdin Wilson 2000 antenna's, custom new rg59 coax. Mounted on a 99 Kenworth W900L. Swr is near set mark. Good continuity, radio just back from shop for peak...
Measure out your coax in 3ft intervals. Like if you need 7ft use a 9ft length of coax. Also make sure your mirrors are grounded use a external swr meter as well, the internal swr on the galaxy could be off. .
Nov 13, 2014 | Radio Communications
Low pwr on xmit,weak rec,swr alert lite on xmit swr 1:4-1 on ch 20
you have no power because your radio is not tuned to your antenna.You get a new radio and put junky coax and a decent antenna and you expect it to work right. Get 75 ft of rg-213 and you will see a change.
Jan 08, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
CAN THE LEGNTH OF THE COAX COUSE THE SWR TO BE HIGH
you should use no more than 18 ft. of coaxhave a tuneable antenna.check your match on the antenna to see if its less than 2.5:1
Jun 10, 2012 | Galaxy Radios DX-929 40-Channels Base CB...
When i unkey my mic, my swr lights come on. sometimes they flicker sometimes the dont, what is wierd is sometimes they stay on for a seccond or two and the meter show full
VR9, VR2 or VR15 may just be out of adjustment. This does assume you are transmitting signal and recieving.
It might not hurt to check with second SWR meter.
Depending on location, there is only a tiny possibility of residual capacitance causing this. However you might want to put a few neon bulbs around your base to monitor for stray RF. If there is stray RF, they will light up- no need to connect them to anything, you can tape them to convenient places you can see. If they do light up- check coax connectors- which you should really do as a routine anyway, and check coax for damage. Then add a flat braid strap ground to "earth bond" for the radio. Which you should have anyway,
Feb 08, 2012 | Galaxy Radios DX-95T Base CB Radio
I have a cobra ltd 29 bt hooking to a 102 inch whip and cannot get m swr readings down under 3 or it will go up higher then the calibrate triangle instead of down. my antenna is mounted with a gumdrop...
  • Sounds to me like you need to check the connectors and connections on that coax. A cobra29 and a 102" whip is a simple enough set up and should not produce that high of SWR unless the coax or the connectors on the coax are pretty messed up. Also i recommend putting an SWR meter in line.
  • The meters on them Cobras can be accurate sometimes but I trust an inline meter much more.
  • Ground it again to make sure.
Regards, Tony
May 17, 2011 | Cobra 29 LTD CB Radio
I have a Midland 1001Z 40-Channels Base CB Radio and a Magnetic-mount CB antenna. 29" stainless steel whip and 6" spring. About 46" high overall. All bought from /www.thesource.ca in Alberta...
Try Grounding it better. Its supposed to equal 8.5 ft.(102 inches) but the coil may make that in all.You can clip like 1/8 inch off at time until it goes 2.1 Swr. Thats a good standard. 1.5 SWR is desired. If it don't have a coil with it that may be the problem. You could turn it into a 8.5 ft. antenna by buying a 102" inch whip to screw into the base of your antenna, it depends if it holds or not. You could build you a matcher like this with a solder gun+solder and 2 resistors. Get you a box with 2 female cb antenna inputs. Drill a hole for both Cb antenna inputs into box. Place them into holes screw nuts down snug. Run a copper wire inside to both grounds or a plate somewhat. Run a thick gauge copper wire from center cb ANT INPUT(2) to other input of ANT INPUT(1). Solder 2 100 ohms in parallel from input to Ground. If you could take apart your radio(eliminating the box idea). Just Solder 2 (100 ohm) resistors to your Antenna output then put it back together. 50 OHM MATCH HERE Is the main idea. I've used 75 OHM Tv coax and reduced SWR.
Apr 04, 2011 | Midland 1001Z 40-Channels Base CB Radio
I have a galaxy dx 959 I had a connex board put in it sometimes it sounds great then the next time it sounds destoreded or a loud sweel
did they put both the power ground and the audio ground together when they installed it? some echo's can only have the one ground , not both.. either the power wires ground or the coax ground on the audio wires.
also check the swr's..
Feb 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Galaxy 95T
check SWR's check to make sure ALL coax connectors are tight. and if still doing it. may be loose connection in board. but the export style radios go crazy like that when coax is loose or have bad grounds. due to there floating ground circuit design. there not the same as a cobra were its case is ground.
Feb 03, 2009 | Galaxy Radios DX-95T Base CB Radio
CB RADIO TRC 446 WILL NOT RECEIVE
IF YOU CANT RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Jan 29, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
Radio will transmit some of the time
Dec 08, 2008 | Galaxy Radios DX-93T Base CB Radio
Radio Communications Logo
182 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
