Question about Tablets & eReaders
Light on the front of the tablet
Why do the light comes on by itself.
  • 1,150 Answers
What Tablet? Not enough info?
Is it an iPad Apple iPad 3rd Generation ?
Posted on Apr 07, 2015
I brought my irulu tablet yesterday downloaded some apps and it started to freeze when I switch it off and back on it takes long to load and also resets itself
I had similar problem with HP tablet which was not answered by them. Later I found it has got DEEP DISCHARGE problem.ie. it is allowing the battery to go to deepdischarge stage due to circuit problem. The circuit should make itself dead and prevent the battery to go to that level. Virtually the battery enters into COMA stage ! Keep it in switch off stage for 48 hours with charging on - so that the battery comes to life again and charges itself. Later my tablet is OK.
Jul 30, 2016 | Tablets & eReaders
Nabi 2S will not charge. I just received the replacement charger and it will still not charge. The light will not come on.
May be light itself out of order? IF you keep charger on for awhile can you feel that battery's getting warmer?
Feb 19, 2015 | Tablets & eReaders
My zeepads screen isn't lighting up. if you turn it just right in the light it can barely be seen. I have tried the back light and the brightness settings on the tablet and the reset..nothing has worked....
If you can see a faint picture on the screen then it is probably the screen inverter is faulty! If it is still under warranty then send it back!
Dec 25, 2014 | Tablets & eReaders
When I switch on the tablet, a face comes up but the tablet doesn't start up. How can I fix this?
With the tablet off, hold the power down for about 10 seconds then let it go and it should reset itself and work properly.
Oct 25, 2014 | Kurio 7S Tablet
My tablet keep come on and off
If the tablet power off by itself suddenly, it might be the hardware issue already.
Please send to the service centre if it is under warranty.
Jul 01, 2014 | ASUS 32GB Transformer Pad Infinity TF700...
My hkc wont turn on? when put on charger the charge light comes on is there anything I can do to turn it back on?
My son had that same problem with his tablet, we panicked before we realized it only needed to be reset. There right next to the volume up and down button there will be a tiny hole. It is the size of a pin tip, it actually says reser, we took a small paper clip and straightened it and it fit perfectly in the hole. Press it for a few seconds and it should come on, it will reset itself.
Good Luck
Mar 07, 2014 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
Black screen
The power cells may be defective and thus the battery will no longer accept a charge. Replace the internal power cells.
Feb 27, 2014 | Motion Computing M1400 Tablet PC
Tmax9 tablet when turn off will come back on and resets tablet and have lost al info:-(
Sounds like a problem with the builtin storage. Tablet may need to be replaced. Check if its still under warranty.
Feb 12, 2014 | Tablets & eReaders
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
