Printer will not accept A4 photo paper. I have ensured that there are no curled edges.
  • Harrie Apr 07, 2015
    Hi Lois Knuchel, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Brand and model please? And what photo paper are you using. Also brand or at least how heavy? Grams sq meter
    Top Expert:
  • 10,875 Answers
What kind of printer? did you ensure that your printer can handle photo paper?
Posted on Apr 07, 2015
I860 will not print a 4 x 6 photo on a windows 7 pc. It gives a message that I have installed the wrong paper. It only wants to print full sheet size photos. I installed the canon add on module drivers and...
Set Envelopes Correctly Before setting envelopes, press down on all four corners and edges of the envelopes to remove curls and bends, as well as any air contained.
Note: The flap of the envelope should be straightened if bent. If the envelope is curled, hold the opposite corners and gently bend them in the opposite direction. If the leading edge of the envelope is puffed or curled up, use a pen, etc. to press the envelope flat and sharpen the crease. (Press the envelope completely flat, working from the middle to the edge.)
i80_envelopes_2.gif How to set envelopes:
  1. Set envelopes to the right side of the sheet feeder. Set envelopes with their longer side vertically and the flap either at the bottom or on the left.
  2. Pinch and slide the paper guide until it firmly resets against the left side of the stacked envelopes.
    Note: The maximum number of envelopes that can be loaded is five.
    <1> Sheet Feeder's right side
    <2> Paper Guide
  3. Set the paper thickness lever to the left.
    <3> Paper Thickness Lever
    Note: Remove the printed papers from the paper output slot cover before five sheets have been ejected.
Also How do I enlarge or reduce my printing size?
Nov 07, 2010 | Canon i860 InkJet Photo Printer
I have a stupid question where the heck do Iload the paper in my Lexmark X2350 printer??
Facing towards front of the printer, on the back of it you have raiser - paper support panel, with side slider on the left hand, push slider towards left in full.
Paper accepted by this printer is all standard grades, like A4, L4 and fall in these dimensions:
width min/max - 76mm to 216mm (3" to 8.5")
lenght min/max - 127mm to 432mm (5" to 17")
Printer will accept paper weight between 60g and 180g, that meant that all standard weight of paper including cardstock will be accepted, printer as well will print photo and envelopes.
• The paper is loaded against the right side of the paper support.
• The paper guide rests against the left edge of the paper.
1. Put paper long way vertical on raiser (paper support), about 80 to 100 pages of standard paper will fit there (depends on thisckness),
2. Push paper against right side
3. Adjust width with left hand slider. Do not buckle the paper!
After print paper is ejected at front bottom slot, printer side up. if you use photpaper or gloss paper, remove it immediatelly as need longer drying time and will get smudget by next printsheet.
You can find information with pictures in your manual on page 13/14.
Hope this will help you print beautiful pictures!
Aug 11, 2010 | Lexmark Z2300 InkJet Printer
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
Oct 18, 2009 | Canon Pixma MP500 All-In-One InkJet...
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper curl
Paper Curl. Does the paper have a curl on the trail edge? (The last part of the paper to exit the printer)
If it is the entire paper replacement of the fuser will likely resolve this.
If the paper curl is on the trail edge then replacement of the upper delivery roller should be done.
Nov 03, 2008 | HP LaserJet 4 plus Printer
Media curls on lead and trailing edges
Any of the following:-
Ensure the correct paper weight settings are in use. Excesive heat will cause paper curl.
Feed paper short edge first.
This is normal with high ink coverage on light paper. Use a heavier weight paper.
Your fuser may need replacing.
Jun 02, 2008 | Xerox Phaser 7750DN Laser Printer
Can't print onto 4x6 photo paper
Did you try this from HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748340&lc=en&cc=us&dlc=en&product=1155996&rule=45149&lang=en
I also suggest you remove the back door & clean the wheels with a clean no lint water dampend rag. Replace the door.
Jan 26, 2008 | HP Photosmart D5160 InkJet Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
jasbo
jasbo
