Question about Emerson Televison & Video
I have an Emerson LCD flat screen TV that will not stay on when I turn it on only the right side of the picture comes on in it is distorted what do I do
    Top Expert:
  • Emerson Master
  • 52,149 Answers
Take to repair shop or buy a new TV
Posted on Apr 07, 2015
dsacco86
  • 1077 Answers
SOURCE: When i turn the tv on it goes to standby right away
If not under warranty, here's what you need to replace inside your TV. Power supply board BA71F0F01042.
The board is hard to find right now. Only three places I know of to find it.
Ebay,
Discount-Merchant.com,
and Shopjimmy.com
Right now, only Discount-Merchant has one in stock. Here's the link:
Discount-Merchant.com - Projection LCD / DLP TV Lamps - Plasma ...
I know it would be cheaper to fix the TV, than replace it.
If you end up throwing the old board in the trash, I would like to keep it if possible. Here's my e-mail, dsacco86@hotmail.com
Posted on Apr 25, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
dsacco86
  • 1077 Answers
SOURCE: my flat screen tv does not have a picture or
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Posted on Sep 04, 2009
mfspencer
  • 58 Answers
SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Posted on Apr 02, 2008
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Emerson lcd tv w/ dvd 19"
Contact the authorized service center for Emerson. The main board to your TV is faulty. A replacement should be done. Gopakumar Gopalan Google
Feb 27, 2014 | Televison & Video
Half of screen is distorted, right side of screen.
please check t-con or inverter board,when you find which boards is defective,you can search by pcb number on www.wisiny.com
Jun 05, 2013 | Emerson LC320EM8 32 in. LCD TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My ns-lcd42hd09 insignia tv only displays the right side of the screen clearly until the tv is on for about an hour then it will display both sides correctly. Today it never cleared up, stays really dark...
Having same problem. Smacking it or applying pressure often works. Extremely annoying (inconvenient) that a nearly $1000 machine breaks down very soon after one year ( how long the warranty is, of course)
Feb 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
