Question about HDCVT SCART/ HDMI to HDMI Video Converter Box 1080P Scaler 3.5mm & Coaxial Audio Out
How do I remove electrical interference on my dvd recorder?
Everytime I put my dvd recorder on, I have constant electrical interference going up the screen,
  • 1,150 Answers
Hi David
You need to figure out how the interference is getting inside.
Look at the external connections.
HDMI Cable or Perhaps the Power Connector.
Noise from the power cable would be most likely.
A Ferrite Bead can often be clipped onto power lead to dampen electrical noise. Electronics supply stores have these.
If an AC to DC external box is used. What is the required DC input to your DVD ?
For example if the AC is dropped to 12v DC and then plugged into player via a small connector. You could get your own connector and supply from a 12v vehicle battery. Be careful to maintain correct polarity to tip of connector.
Use a cheap multimeter to check voltage & polarity.
Substitution....This would prove that the noise source is from the Power Supply.
Cheers
Posted on Apr 07, 2015
Everytime i install m audio into my computer and when i go record it sounds staticy , what should i do ?
Perhaps the mic is picking up interference from the computer and/or screen. Try moving it around and place it further away to see if that helps.
Mar 06, 2011 | M-Audio Producer USB Microphone with...
Everytime I try to record it says movie recording disabled
You must have put file erase lock on a DVD you put in camera, just replace with an unlocked DVD ok?
Jun 02, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
We have a philiips dvd recorder, but unable to
switch tv to the input mode you have conected dvd to e.g ( AV or EXT ) if dvd is a recorder one have you put areal in back and tuned in dvd recorder
Nov 28, 2009 | Philips Televison & Video
Gateway AR 230 Recorder recording sound has interference noise
Disconnect the "audio-out" cables from the unit.
Leave the "audio-in" cables connected.
Try to record. Does this work correctly?
Apr 21, 2009 | Gateway AR-230 DVD Recorder
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Gray box shows up on TV screen..
make sure the subtitles are turned off on the tv and the player
May 28, 2008 | RCA DRC8320 DVD Recorder/VCR
I'm experiencing problems with a Panasonic DMR-EX87 DVD recorder that is less than 6mths old. In the last few months while watching programs recorded to the hard drive, the picture often breaks up in the...
My guess is that your DVD player is malfunctioning. I'd check the warranty and just try and get another. The problem you're describing sounds like the DVD hardware is probably messed up.
May 23, 2008 | Panasonic Televison & Video
LVW 5104
check the disc maybe the recordable disc. some disc are written DVD+R/DVD-R/DVD+RW/DVD-RW. check if it is compatible with the recorder.
May 03, 2008 | Lite On LVW-5005 DVD Recorder
Connecting a additional dvd player
Try this:
Player Recorder
S-video-out => S-Video in
red & white audio => red & white audio in
out
Dollar stores are a good source of cheap cables,
but macrovision protection may interfere with the
recording... www.videohelp.com may provide a code to
disable macrovision on the player.
Jan 25, 2008 | GoVideo VR3845 DVD Recorder/VCR
HDCVT SCART/ HDMI to HDMI Video Converter Box 1080P Scaler 3.5mm & Coaxial Audio Out Logo
Top HDCVT Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HDCVT Audio Player and Recorder Expert? Answer questions, earn points and help others
