Question about Dryers
My dryer is not spinning. It turns on but does not spin. I heard a loud clunk when I took out clothes and spun the drum clockwise.
  • Dryers Master
  • 2,210 Answers
Sounds like a broken drive belt.. pretty easy replacement. check youtube.com, repairclinic.com, or appliancepartspros.com for videos to show you how.
Posted on Apr 07, 2015
  • Anonymous Apr 07, 2015
    Thanks! Will definitely look into that
barkencoa
  • 3463 Answers
SOURCE: dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Posted on Dec 14, 2008
  • 71 Answers
SOURCE: Kenmore electric dryer vibrates loudly
Yes the kenmore uses the roller wheels . dr fixit in the service providers has them. Any way I can help otherwise?
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Posted on Dec 20, 2008
  • 198 Answers
SOURCE: dryer spins counter clockwise
When installing new belt the belt comes off the right side of the drum and through the idler and around the motor shaft, then up the left side
Posted on Jan 07, 2009
  • 24 Answers
SOURCE: The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
Posted on May 19, 2009
My dryer gets hot but doest dry my clothes i lifted the top and spun the barrell around and noticed that the seal is torn could that be the cause
Sounds like a belt problem with no clothes in the dryer turn the dryer on for a minute or so open the door if the drum is spinning it not belt if drum is not spinning it's more that likely the belt that turns the drum.also need to check the exhaust hose in back of dryer it could have a blockage check lint screen also.Hope this helps.
Oct 20, 2016 | Dryers
Got clothes out my dryer and turned the drum clockwise to get a lint. Heard a loud clunk noise and now it wont spin. Please help
check for a broken drive belt for the drum
the clunk may have been from the belt as it broke and hit the cabinet
Apr 07, 2015 | Dryers
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
My maytag washer stopped working during the wash cycle. it made a clicking noise when it happened.. I pulled off the belt it is still in one piece . when i put the maching in spin with the belt off the...
If you turn the transmission pulley one way it will agitate the other it will get hard raise up to release the brake and then turn the transmission and the inner drum. If you cannot turn the drum then I would check to see if a nail has gone through one of the holes in the bottom of the drum or a piece of clothing has jammed between the top of the drum and the top cap of the outer tub.
Nov 01, 2010 | Maytag Performa PAV3200
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Kenmore oasis washer
top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Apr 01, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Dryers Logo
65 people viewed this question
Top Dryers Experts
