Question about Dryers
Got clothes out my dryer and turned the drum clockwise to get a lint. Heard a loud clunk noise and now it wont spin. Please help
    Top Expert:
  • Dryers Master
  • 42,546 Answers
Check for a broken drive belt for the drum
the clunk may have been from the belt as it broke and hit the cabinet
Posted on Apr 07, 2015
  • Anonymous Apr 07, 2015
    Thank you. Will look into it!
Cerfer39
  • 709 Answers
SOURCE: dryer
Hi Kyboy49,
The drum rolls on idler wheels. Sometimes the lint and stuff clings to these wheels and causes the cluncking noise you speak of. You will have to pop up the lid and see if you can reach the wheels for cleaning. You may have to pull the front panel off.
Posted on Nov 07, 2007
  • 489 Answers
SOURCE: clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Posted on Jun 11, 2008
barkencoa
  • 3463 Answers
SOURCE: dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Posted on Dec 14, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: Maytag Dryer clunking noise
may 26 2009
My maytag dryer is making a very loud squelling sounds in some of it cycles. still drying ok
gmalcom
Posted on May 26, 2009
My dryer is not spinning. It turns on but does not spin. I heard a loud clunk when I took out clothes and spun the drum clockwise.
sounds like a broken drive belt.. pretty easy replacement. check youtube.com, repairclinic.com, or appliancepartspros.com for videos to show you how.
Apr 07, 2015 | Dryers
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
Dryer is making loud noise when drying. Listen to video. Help
I heard the sound and that is not an unbalanced drum. I think you have either bearings going out or your drum belt needs to be replaced. When that wears down it causes the drum not to run true giving it that metal on metal sound.
Jan 22, 2013 | Dryers
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer making loud clunking noise
Dec 14, 2008 | Kenmore Dryers
My lint filter assembly is broken. I was drying a small load of clothes and the lint filter got tangled with clothes and came out into the drum. The dryer was stopped when I found this situation. ...
The drum should turn either direction. Part of the filter must be catching in the belt at the drum or motor when turning clockwise. CCW would push it out away from the belt so no pinching.
May 29, 2008 | Amana Dryers
Kenmore oasis washer
top loaders use the same motor for wash pump and spin to spin the clothes the motor direction is reversed and a solenoid releases the drum brake allowing the drum to rotate this is governed by a set of clutch shoes in the pulley if these are worn then the machine wont spin at full speed but ol on the display indicates overload so check the solenoid is releasing the drum usually heard as a loud clunk on spin start
Apr 01, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Dryer
Hi Kyboy49,
Oct 23, 2007 | Whirlpool LGR7646E Dryer
Dryers Logo
74 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
