Question about Electronics - Others
My inverter keeps reading lvp but my battery is new and fully charged.as soon as I plug any thing even a 40watt light bulb it pulled down to 11.6 and lvp goes off
SOURCE: Samsung SGH-T219 Turns off even though it says fully charged.
my phone is 1 week old and it does the same thing
Posted on Dec 26, 2007
SOURCE: Tatronic inverter problem
Tightened up battery connections
Posted on Sep 24, 2008
SOURCE: Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Posted on Dec 08, 2008
  • 14 Answers
SOURCE: battery only keeps a charge for about 10 seconds
Sounds like the switch is dirty and turning off ... take a look at this video and see if you need to clean it. Mine would not charge or run until I cleaned the switch contacts.
http://www.youtube.com/watch?v=9b7lf5hqjag
Posted on Apr 28, 2009
SOURCE: Inverter fan kicks on after turning on a light bulb
yes the ic chip tells fan to start up.
Posted on Jul 27, 2009
We have 04 Dutchman hornet 32' we have replaced the battery however we do not have power and are lights are dim even we are plugged in to the electrical box. Read everything runs through pinverter
Caravan electrical systems are complex and the more modern they are, the more complex they are. The addition of a comprehensive control panel to make it easier for the operator adds further complications and the wiring diagram included in the manual is invaluable when there is a problem.
For safety reasons it is common practice to have at least one low voltage light that is capable of being operated as soon as the battery is connected - usually a bulb at or near the entrance that almost regardless of any other faults the electrical system might have should operate at full brightness with a fully charged battery.
If you have such a light and it is bright it sort of indicates the 12 volt circuit is working. Caravans are notorious for poor and corroded low voltage ground connections.
I don't imagine everything goes through the inverter. An inverter takes such a lot of current few people would elect to use a power inverter continuously and when using a mains hookup there would simply be no point. I imagine there is either the added complexity of automatic switching or interlocking manual switching.
That the lights are dim even using the mains hookup is probably significant but more than that it is impossible to venture as only tracing the circuit using the circuit diagram and checking voltages is likely to discover the reason.
Oct 07, 2017 | Cars & Trucks
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Hampton bay fan 40watt bulbs barely come on
Are you just using pull chains for fan & light?
Oct 20, 2015 | Hampton Bay Dryers
Car wont start has charged battery lights and radio come on new starter. drainging battery even though the battery is fully charged its reading its not tempature gauge reading hot but its not runn
If the problem began when (or soon after) installing the new starter, start checking there. Ensure that all cables to the starter are tight. As a second possibility, if the new starter was actually a rebuilt replacement, the solenoid could be faulty. (I went through three rebuilt starters on my son's truck until we got one that worked properly.)
Mar 06, 2014 | 2004 Ford Mustang GT
Gateway laptop shuts down instantly when unplugged but fully charged.
I have come across connection issues on the battery terminals. Make sure the brass contacts are not tarnished or bent. Have you tried another battery?
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
My ridin more battery keeps dieing ,i got a new battery still same problem
Firstly i would check the battery leads are good and tight both ends and your earth is not corroded on machine chassis or engine block. Next, is machine charging at its correct voltage, anything between 13 - 14.5volts is expected, do this with engine running at half revs and connect a volt meter to the battery, set to read DC volts. Its also adviseable to do this when the battery is fully charged as you will get a more stable and accurate reading. If your reading is between 13 - 14.5volts then charging system is good, less than 13volts, not charging, more than 14.5volts, over charging. Both of the latter will give you problems.
If your charging circuit is ok, remove key from ignition, remove the earth ( Black, Negative) lead from the battery and connect a small 12volt bulb between the earth lead and negative pole on the battery. If the bulb glows, no matter how dim, then you have a leak off, an electrical component on the machine is drawing current which will flatten the battery. Identifying the component is a process of elemination by carefully disconnecting all wires on the machine one by one untill the bulb goes out. Example; bulb is glowing so remove a wire, any wire and if the bulb goes out then the fault is at either end of that wire, if it doesnt go out simply push it back on and move on to the next wire. Start in the easiest places first and remember, one wire at a time (unless there are any multi plugs then just pull the plug apart) and refit if bulb stays lit.
Jun 21, 2011 | Mtd Garden
I have a jet3 ultra that has never been used. In October we bought new batteries. It worked;however, we have not used it or charges it until now. The omnimeter reads 0 and only the one red light shines. ...
amy why did you not keep the batteries charged? even new batteries have to be charged before use. Now plug in the charger and look at the meter with the charger plugged in the meter will show some reading around 4-5 amps. Let the charger work overnight when you get up in the morning fully charged the meter will read zero. Turn on the chair and all the battery lights should be lit. If after charging over night you are still getting one red light then you blew 170.00 and no amount of charging will bring them back. Sorry I wish I had better news. If you replace the batteries charge fully before use and then use the chair some each day and charge nightly for 20 days this will break in the batteries and get them operating at 100%. If you then only use the chair sometimes always put it up fully charged and charge at least once a week If you use the chair for that day charge overnight and it will be ready to use again when you need it. If you are going to leave the chair unattended for 6 months then fully charge the batteries and disconect them from the chair until you need it again New batteries every 6 months can get expensive Hope this helps you
Apr 17, 2011 | Health & Beauty
the inverter fan just kicks on to keep the system from overheating. Its perfectly normal.
Jul 24, 2009 | RoadPro RPPI-2500W Inverter
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Electronics - Others Logo
170 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
