Question about Kenmore Washing Machines
Kenmore elite quiet PAC 9 sounds like a belt is squeaking and possibly a bearing is going out
    Genius:
  • Kenmore Master
  • 1,585 Answers
Could well b but try belt
Posted on Apr 13, 2015
  • tom cassidy
    tom cassidy Apr 13, 2015
    try fairy liquid small drop as it slips it goes tacky not perm fix replace belt
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Quiet Pac 9 Front Load Washer
"Fdl" is a door latch error code. This can be an indication of a broken door latch, or a bad central control unit (CCU). It can also mean loose interconnecting wires. Since you indicated that the latch doesn't make any noises such as attempting to lock at the beginning of the wash cycle, I would suspect the door latch as the problem, before I would suspect the control unit. The door latch doesn't cost much (usually around $35) and is a fairly simple repair to make on your own. If you wish to attempt a repair here's the steps required to replace the switch and how to perform diagnostics:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
NO SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Posted on Feb 10, 2008
SOURCE: Kenmore Stacked Washer / Dryer Model Number 417.97802792
can the rear bearing on the drier be oiled/greased though the back casing, any easy way of stopping sqeek!
Posted on Oct 14, 2008
  • 99 Answers
SOURCE: Washer hasn't completed the spin cycle and is flashing 02 then f
this is joyce
what kind of waher have you got? model #
Posted on Feb 06, 2009
  • 5 Answers
SOURCE: my kenmore elite smartwash quiet pak 9 he 4t seems to be off
have you tried lower spin speeds? I found with heavy items such as towels and jeans it is best to lower the spin speed. also washing like heavy items on a certain wash cycle is best - i.e. towels on bluky/bedding.
hope that helps.
Posted on Apr 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore elite smart Wash quiet pak 9
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
I have a Kenmore smart wash quiet pack 9 HE5t and when I try to turn it on it make a noise but won't turn on
Please check the motor belt , the drain pump and the inlet valve. If the noise seems to come from any of these it is possible that it trips off the circuit due to a fault and so must be confirmed.
You can remove the connection to the seperate items to confirm if the panel switches on.
Jul 02, 2012 | Kenmore Elite HE5t Washer
Dryer is making a squeaking noise when it is drying?
It's either 2 things, a squeaking belt and/or the bearings in the electric motor.
Jan 08, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite kingsize quiet pac 2
make sure your belt (inner rear) is in tact
Mar 29, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
35 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
