Question about Dell Computers & Internet
My dell 2305 pc has started making loud humming that will continue several minutes, and then the screen goes black.what could This Be ? HELP ! !
  • Dell Master
  • 928 Answers
Check the fan, maybe the fan is stuck, dirty or just at the end of it life cycle
Posted on Apr 07, 2015
    Sergeant:
  • 233 Answers
If the machine boots up and you see the operating system start.
Then the loud humming could be fan dying as william stated.
If the fan speed max's out and the fan blades do not turn. It will sometimes hum very loud. The screen blanking out could be the system reaching heat levels too high. PC's often have more than one fan. Open the case and check for dust clogging the system.
Blow this out with compressed air. Vents, fans, fan blades etc.
Then see if the system runs within normal temps.
Note: hold the fan blades while using compressed air. You do not want these to spin at crazy speeds which will happen with the compressed air. Replacing any of the internal fans is simple.
Usually 4 screws and a power plug.
If the fans turn and do not pause or hang. I would then suspect the power supply. If your comfortable working inside the computer.
Switch out the power supply and hopefully this will resolve the loud humming. I have actually watched as a power supply died.
Humming noise then a little wisp of smoke. Dead as a door nail. :)
Good luck and hope this helps.
5 Suggested Answers
WASTED28301
  • 50 Answers
SOURCE: The pc not starting up
TRY F8 WITH NETWORK SEE IF IT STILL SHUTS DOWN IN 10
OPEN THE SIDE TO LOOK INTO THE SYSTEM TO SE IF THE CPU FAN IS SPINNING AND SEE HOW CLEAN OR DIRTY IT IS. IF IT'S SPINNING SHUT IT DOWN AND DIRTY YOU'LL HAVE TO CLEAN IT UP,THEY HAVE AIR IN A CAN
USE THAT TO BLOW OUT THE JUNK IN THE SLOTS AND SEE WHAT HAPPENS WHEN YOU FIRE IT UP THIS TIME
Posted on Oct 11, 2011
  • 137 Answers
SOURCE: when i turn on my
stop Turning on.
the reason may be either of them:
1. Hardware faulty.
2. Loose cables/cards
3. Bad CMOS clock.
we deal with all of them.
1. Change CMOS Battery and short free the RAM by jumper(Uou need to check the manual or let me know the model.
2.reseat all the cables and Cards.
Boot the system Now.
Still give a long Beep?
(It may be a Hardware gone bad) But we need the confirmation for HW itself. We may conduct tests.
Dell Systems are reliable and least troublesome.
Rate this solution, Write a comment to keep in touch.
Posted on Sep 16, 2010
  • 3 Answers
SOURCE: Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
Posted on Jun 28, 2010
SOURCE: HDMI input says No input signal After about 20 minutes of monitor being on it starts making a loud buzzing noise and eventually the screen turns black.
could your graphics card be bad?
Posted on Apr 11, 2012
Dell inspiron one 2305 black screeen with one flashing light
Dell Inspiron One 2305 (all-in-one) that will not power on. ... to reboot, I saw a faint white flashing light and heard a faint clicking noise. .... but I still have the black screen and my 2305 model remains essentially "dead".
Apr 18, 2014 | Dell Inspiron One 2305 Desktop Computer...
My dell Inspiron one desktop touch screen shrink
you must reconfigure your display settings in control panel
Feb 10, 2014 | Dell Inspiron One 2305 Desktop Computer...
Black Screen
start computer in safe mode with command prompt then run chkdsk /r on the C Drive.
Dec 31, 2013 | Dell Inspiron One 2305 Desktop Computer...
I cannot access my computer because somehow it developed a need for a password
Reboot your computer as soon as the Dell logo comes up hit the delete key and get into system bios. You will have search through the bios until you get to password then unclick it. The system should start normally. You could call Dell they will walk you through it.
Dec 12, 2013 | Dell Inspiron One 2305 Desktop Computer...
Starts Windows then goes to black screen
Hi try hitting F8 when system is booting up, you can select safe mode or last know good configuration. Check also if you installed a new hardware/software on the system. Last option will be reinstalling a new windows. Hope this will help. Cheers
May 07, 2013 | Dell Inspiron One 2305 Desktop Computer...
I've got a Dell Inspiron One 2305...the problem with it is that when push the start button I can actually hear the computer starting up BUT the display is BLACK....no logo,no sound,no nothing. It&
You can try connecting an external monitor to see if you get a display on the external monitor. If so then you have a problem with Inspiron LCD screen or video circuit on the motherboard. Here is a link to the setup guide which has the location of external VGA connector on the back view:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-one-2305_setup%20guide_en-us.pdf
Mar 06, 2013 | Dell Inspiron One 2305 Desktop Computer...
My Inspiron one 2305 is not working. I turn the power on and the light is solid white but after a few seconds it turns solid amber, and all i can see on the screen is the dell logo. and on the lower right...
Repair PC
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
SAFE MODE
At start up press F8 go2 SAFE MODE thn type at run chkdsk,chkdsk/f/r & thn restart pc
Else Repair XP
Else clean ram BY RUBBER
Mar 16, 2011 | Dell Inspiron One 2305 Desktop Computer...
May 20, 2010 | Dell Dimension 4700 PC Desktop
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
Computers & Internet Logo
109 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
