Question about HP Computers & Internet
Hey how do i access the keys ie brackets - HP Computers & Internet
    Novelist:
    Scholar:
  • 167 Answers
Hold down the Shift Key while pressing a bracket key.
That is press them in combinations like :
Example: Shift key and ( key
Shift key and ) key
Shift key and [
Shift key and ]
Actually you can use the Shift key in combination with any key to access the secondary character on keyboard.
Posted on Apr 12, 2015
Need a key-stroke combination to access the recovery partition.
Hey there, After doing some googling it seems that the default key for dell PCs to access the recovery partition is pressing CTRL+F11 while your computer is booting up.
I hope I was able to help.
Jul 27, 2011 | Dell OptiPlex 780 MT PC Desktop
Hey could you give me a step by step on how to replace the lock cylinder on a Oldsmobile Alero? I have a new lock cylinder with the keys. Thank you
Usually the new one comes with instructions, but the Alero is a bit tricky. There are 3 bolts holding the lock bracket to the dash. 2 are accessed by removing the radio (not all the way, just pull it out and DO NOT unplug the wires from it.) The trim panel on the radio pulls right off, it is just there with plastic clips. The 3rd bolt is behind the instrument cluster which must be removed. Takes about an hour altogether. Remember to follow the relearn procedure to let your car alarm remember the new key's resistance value. It should be with your lock info. A good step by step can be found here:
http://www.2carpros.com/questions/2000-oldsmobile-alero-do-i-need-a-specialty-for-this-repair
Remember to use the info I gave you previously with that procedure and you should do fine. I've done several of these with the key frozen in them and still only took about an hour......Mike
Jul 13, 2011 | Oldsmobile Alero Cars & Trucks
I need to find my wireless setting
If you need to find the wireless key set up on your router, the Internet Service Provider usually places a tag on the device with the default key.
You can also reset the device to the default factory settings by holding down the reset button for a determined period of time depending on the manufacturer. Then you can log into the device using its IP address and default username and password in order to change the wireless key.
You can visit your router's manufacturer web site for more info on the defaults.
May 06, 2011 | Computers & Internet
I have a 2wire Gateway wireless modem Model 2701hg-b. Not sure where the paperwork is. Need to know how to determine PIN. Thanks
The pin is usually on a sticker on the bottom of the unit. This is the only router that has it like that, I wish more of the MFG would do it.
That key is the 10 digit number that's off the bottom of the 2wire (the one in brackets (ie [0123456789]) but only the numbers).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 19, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
What are the parts of casio calculator
LBrown18062@hotmail.com My manual is 75 pages. I can email it to you. Please put Casio FX-115ES as the subject. Awaiting your response.
fx-115ES User's Guide
About this Manual
• The MATH mark indicates an example that uses Math format,
while the LINE mark indicates Linear format. For details about
input/output formats, see "Specifying the Input/Output Format".
• Keycap markings indicate what a key inputs or what function it
performs.
Example: 1, 2, +, -, !, A, etc.
• Pressing the 1 or S key followed by a second key performs
the alternate function of the second key. The alternate function is
indicated by the text printed above the key.
• The following shows what the different colors of the alternate
function key text mean.
If key marking
text is this color: It means this:
Yellow
Press 1 and then the key to access
the applicable function.
Red
Press S and then the key to input the
applicable variable, constant, or symbol.
Purple (or enclosed Enter the CMPLX Mode to access the
in purple brackets) function.
Green (or enclosed Enter the BASE-N Mode to access the
in green brackets) function.
• The following shows an example of how an alternate function
operation is represented in this User's Guide.
Example:1s(sin-1)1=
Indicates the function that is accessed by the key
operation (1s) before it. Note that this is not part
of the actual key operation you perform.
sin-1{D}
Keycap function s
Alternate function
Jan 19, 2011 | Casio FX-115ES Scientific Calculator
I did not know my network key for wireless lan, Satellite L300 se
The network key is an encryption key ie. WEP/WPA-PSK key.
This key is configured in the wireless setup of the wireless access point or wireless router.
The key can be a hexadecimal number but most people use a Passphrase.
The Passphrase can be a phrase such as "I'm am so smart 12345" and this is used to generate the hexadecimal encryption key.
For instructions on setting up and configuring the wireless security for your access point (this apply to wireless access points and wireless routers), please click in this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 22, 2009 | Toshiba Computers & Internet
Need licence key for smart movie
358973012739989
key: 41267
358973016279024
key: 31604
Oct 26, 2008 | Nokia N73 Cellular Phone
Intellent router
can you give more info in how are you trying to access the interface. are you in the same network or are you connecting from another place. have you enable the remote access on the router?
Mar 11, 2008 | Intellinet Active Networking (520638)...
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
