Question about Intermatic 24 Hour Outdoor Timer HB31R
No going off and on with pins anymore
Setting back up for summer with current time to run pond pool. Will not kick off and on where pins are placed. How to resolve this issue. THANKS
  • Mary Jim chapman
    Mary Jim chapman Feb 14, 2016
    Same problem here solution : timers tripping legs worn off. Time to replace timer
  • Intermatic Master
  • 5,245 Answers
If dial is still rotating, then buy new trippers:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Apr 07, 2015
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
Index sand filter pump SF 20110 will not blow water into pool
I don't know how much time you are giving it, but sometimes when I start my pump, it'll take 20 minutes or so for it to start a full stream of water. Also, make sure the valves are turned to the unlock position on the incoming and outgoing hoses.
Jun 03, 2014 | INTEX Sand Filter Pump
Runs
pool pumps should run at least two hours for every one hour of pool use , this should be doubled if pool recieves a heavy useage of more than three swimmers timers on most of the intex models are set with trip pins , in towards center to be off and out from center to be on
Jul 13, 2013 | INTEX Sand Filter Pump
Intex pool surface skimmer keeps floating up.
i solved this with a few fishing weights in bottom catch cup takes a little experiment (more/less) to get it floating just right but once you do it works all summer
May 30, 2012 | Intex Surface Skimmer Pool Vertical...
Summer escapes pool pump won't turn on
Take a look for new pump on amazon, click here: Amazon com pool pump. I hope this was helpful. Cheers
May 14, 2012 | Pool & Spa
I just had a representative from the Geek Squad set up my Epson WorkForce 633 Fax/Printer/Copier. The time that we set up is not what I wanted. I want a 12 hour set up, and I need to reset the clock on...
Below you will find the instructions straight out of the manual. I have also put a link to the whole searchable HTML manual at the bottom of this post Enter the Date and Time Before setting the date and time, you should select the appropriate Daylight Saving Time setting for your region. This setting lets you easily set the clock one hour ahead or one hour back when the time change takes place. 1. Press the fax.6.7.1.jpg Setup button. 2. Select Printer Setup. You see this screen: fax.6.7.2.jpg 3. Select Daylight Saving Time. 4. Select Summer if your region uses Daylight Saving Time and it's currently in effect. (DST is effective from spring through summer.) Otherwise select Winter to turn off the setting. Note:
When you change the setting from Winter to Summer, the clock is automatically set ahead by one hour. When you change it from Summer to Winter, the clock is set back. The setting is not automatic; you need to change it each season. 5. Select Date/Time. You see this screen: fax.6.7.3.jpg 6. Select the date format. You see this screen: fax.6.7.4.jpg 7. Use the numeric keypad to change the date, then press OK. fax.6.7.5.jpg 8. Select the time format. fax.6.7.6.jpg 9. Use the numeric keypad to change the time, then press OK. 10. Press fax.6.7.7.jpg Back until you return to the home screen. Epson Work Force 633 Manual Hope this helps. Zeppelinx12
Mar 10, 2011 | Office Equipment & Supplies
Pool motor kicking the breaker only after a few minutes .
If the pool pump is running and then 10 minutes into the cycle it trips the breaker, then it is overloading the circuit. The pump is laboring, workingf too hard . The filter shoiuld be cleaned. maybe there is a blockage in the return line to the pool. the other thing could be the wire size to the pump, but you said that it was running last summer . so that should be OK
May 11, 2010 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Changing time on navigation
Time
Adjusts the systems clock. The time difference
(+, –) between the time originally set in your
Navigation System is set here.
You can also select summer time On/Off.
➲ Time settings ➞ Page 108
Summer Time
Choose whether or not to take summer time into
account.
On :
Summer time is taken into account.
Off* :
Summer time is not taken into account.
❒ When the period of summer time comes, or
when the summer time ends, your Navigation
System does not automatically change the
summer time setting.
➲ Change the summer time setting ➞ Page 108
Modify Current Location
Touch the screen to adjust the current position
and direction of the vehicle displayed on the
map.
Hardware Info
Touch “Hardware Info” in the Setting Menu to
display.
Connection Status
Connection Status ➞ Page 61
3D Calibration
3D Calibration ➞ Page 60
Service Info Screen
Displays the disc production number and version
information.
Mar 14, 2009 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Intermatic 24 Hour Outdoor Timer HB31R Logo
181 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
