Question about Dual XDM6220 AM/FM/CD/MP3/WMA Receiver
Where does the 12v ign,batt and remote wire go on the 12 din conn on back of deck
How do I get my aftermarket radio to shut off with the ignition
You should have a cable marked ign + on the wiring loom of your aftermarket unit this needs to be connected to the 12 volt ign cable on the cars wiring loom , easiest way to identify this cable is with a multimeter you should have one permanent 12 volt DC and 1 x 12 volt DC that comes on and off with your ignition key. So 1 permanent 12v and ign 12v make sure they are the right way if your cables are not marked on the radios wiring loom get a manual to check which colour is the ign wire it's usually yellow or orange but check the schematic first before connecting any wiring.
Apr 29, 2014 | Car Audio & Video
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
Distributor not firing on a 92 tercel
Don''t know who or how this check was done but should compare resistance between terminals on coil with another small difference was my problem 1991 tercel you can also hook 12v batt. pos. to +term.on coil with sparkplug and wire conn. directly to coil grounding outside of plug to neg.term. of batt. now connect wire to -on coil and momentarily touch to batt. - you should get spark across gap of plug .This will determine for yourself if coil is indeed good or bad. I was very surprised another coil from junkyard cured problem!!!
Aug 17, 2012 | 1992 Toyota Tercel
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a 94 merc cougar xr7 with a 3.8. the batt light is on and the volts are reading 12.38 roughly when running. the ignition wire has 12v rinning to it and the batt wire to the back reads 12v. the...
Need to check voltage at back of alternator, should have no less then13 volt's, if you do alternator is good, this is just a self test for you, with engine off, with test light check for voltage at back of alternator, test light should light up, if it don't look for blown fuse link at starter solenoid on fire wall. most of the time a fuse llink will have a tab on the wire, pull genly on wire, if it feels rubber like, bad fuse link,
Aug 17, 2010 | 1994 Mercury Cougar
I bought a used pioneer car stereo/cd player for my boat,battery wire marked, acc marked ( what does that wire up too?? ) & remote wire?? wat does it hook too ??
battery(yellow) goes to power that is ALWAYS on.(straight to + on batt) red or acc goes to accessory position of ignition key. (if no acc then wire to ign on(unless you want to listen to it with boat off then wire to batt + also but deck will be always on. REM is remote switch wire(gets power when h/u is on) and is used to turn on the amplifier if you have one or to make electric aerial go up. if you don't have either then don't worry bout it. leave it off but tape up the end.
Jun 18, 2010 | Car Audio & Video
Eating alternators mitsubishi shogun 1994 2.5td gls
is your a 12v or 24v some imports are 24v and engine parts are different thanks brian
Mar 07, 2009 | 1988 Mitsubishi Pickup
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
Pioneer deh-2000r wiring
Pioneer usually use:
red - 12 volt batt. ignition/acc
yellow - 12 volt batt. memory
black - ground
blue - power ant.
blue/white - amp turn on
orange - illumination ( 12 volt light ) ( not all deck )
orange/white - dimmer ( not all deck )
gray - right front +
gray/black - right front -
white - left front +
white/black - left front -
violet - right rear +
violet/black - right rear -
green - left rear +
green/black - left rear -
Is this what your looking for?
Dec 01, 2008 | Pioneer DEH-1600 CD Player
Remote wire
You have the REMOTE wire hooked to a constant +12V source. The remote wire is supposed to correspond to the ACCY wire to the vehicle, usually through an aftermarket Audio DECK. If it is reaming on when turning the key OFF the wire you currently have it spliced to is a CONSTANT +12V , which is connected directly to the battery. If you do not have a aftermarket Deck, hook the remote wire to the ACCY wire conecting to the factory radio.
Jun 19, 2008 | Car Audio & Video
Dual XDM6220 AM/FM/CD/MP3/WMA Receiver Logo
128 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
