Question about Singer Sewing Machines
How to replace motor belt on singer 2ooo atens
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
I think you're referring to the Singer Athena 2000, a slant needle, touch and sew machine.
I don't have a service manual for that machine, but on all the machines that I have worked on, there are two belts near the hand wheel, and the tensioner is at the center--the part where both belts come together--and you can adjust it by loosening two Phillips screws.
However, before you attempt something like that, you will need the parts number, and I would purchase the service manual. You can get a part list free and purchase the service manual here. Singer Athena and Touch Tronic
Posted on Jul 06, 2015
How do I put a new belt on a Singer 99K?
loosen the bolt that holds the motor mount to the machine body and slide the motor up and the belt off. Replace belt with the same length belt and re-tighten motor mount bolt. The belt should not be too tight or it will slip, or generally run poorly.
Dec 10, 2016 | Singer Sewing Machines
My machine is not running ,the motor sounds like it ok but the bobbin is not moving? Thank you It is a Singer 3116 Simple
if the motor is running and neither the needle or the hook are moving, then your motor belt has come off(the motor will sound like it is racing). If the needle is moving, but the hook is not, you may have a broken gear, or timing belt.
Dec 01, 2016 | Singer 3116 Simple
How can I tell what year or model a Singer is?
Hi Donna,here's a link to your Singer,just enter your serial number to find out what year model it is. Singer Sewing Machine Company Serial Numbers
Sep 29, 2016 | Singer Sewing Machines
Is it possible to get a replacement motor for my singer 9836c sewing machine
Yes, it is available at Sewing Parts Online for $91 plus shipping. When you go to the site, just select "Singer Parts" from the menu on the left, then enter your model number in the search box, and you'll see it; it is part #362180-012. You'll also see that it's the motor for a number of other machines, which is probably why you can still buy it.
Feb 20, 2015 | Singer Sewing Machines
My mom's old singer will start sewing then slows down to a stop.
Try loosening the new belt. The object is to put the belt as loose as you can but tight enough that you can stall the hand wheel without the belt slipping. Once you've done that, loosen the clutch and let the motor run freely for a while. Sometimes people put too much oil on the motor. It only needs 1 drop every 10 years or so. Running it for a while lets some of that excess burn off.
Aug 11, 2014 | Singer Sewing Machines
It may need a REALLY thorough cleaning & oiling, Cindy, including the motor bearings. The motor's windings may be getting weak, too, or the new belt may be slipping.
I bought a Singer 328K at a second hand shop. I cleaned and oiled it but the motor just hums and runs very slowly. I think the belt may need tightened or replaced. Is it possible to do it myself and...
The Singer 328K "style-o-matic" is a Class 66 sewing machine with a solid handwheel. Like the 328, and most style 66 machines, this one takes Singer Motor Belt # 193077. Any singer vendor should be able to help you and as of this writing (2010) the part runs around $10. In case you have a parts machine around or find vendors less knowledgeable here are some other machines using the same belt: Pfaff 330 Series Singer 127 Singer 128 Singer 15-88 Singer 15-90 Singer 15-91 Singer 185 Singer 185K3 Singer 206 Singer 206K Singer 223 Singer 27 Vibrating Shuttle Singer 306K Singer 306W Singer 319K Singer 327K Singer 327K Singer 328K Style-O-Matic (YOURS) Singer 329K Singer 66 Singer 66-1 Singer 66-14 Singer 66-16 Singer 66-18 Singer 66-24 Singer 66-4 Singer 66-6 Singer 66-8 Singer 99 Class Singer 99-13 Singer 99-31 Singer 99K
Hope this helps!
Aug 14, 2010 | Singer Sewing Machines
Singer Tiny Serger: Motor runs but machine
pull the 4 bottom rubber feet out and remove screws hidden in holes. Lift main body of serger up. you will see the gears. Probably drive gear on motor shaft got hot and slid on motor shaft.
Dec 10, 2009 | Singer Tiny Serger TS380
Sewing Machines Logo
201 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
