Question about Chrysler 2011 200 LX
How to reset you need a oil change indicator - Chrysler 2011 200 LX
    New Friend:
  • 22 Answers
Turn the ignition switch to on position but don't run the engine,then press the accelerator pedal 3 times within 10 seconds after that start the engine to check the light.
Posted on Sep 04, 2016
Reset oil change indicator on 2011 Dodge Charger
Your vehicle is equipped with an engine oil change
indicator system. The "Oil Change Due" message will
flash in the EVIC display for approximately 10 seconds
after a single chime has sounded to indicate the next
scheduled oil change interval. The engine oil change
indicator system is duty cycle based, which means the
engine oil change interval may fluctuate dependent upon
your personal driving style.
Unless reset, this message will continue to display each
time you cycle the ignition to the ON/RUN position. To
turn off the message temporarily, press and release the
MENU button. To reset the oil change indicator system
(after performing the scheduled maintenance), perform
the following procedure:
1. Without pressing the brake pedal, push the ENGINE
START/STOP button and cycle the ignition to the ON/
RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, push the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Source: Owner's Manual page 293
Dodge Charger Owners Manual
Oct 22, 2012 | 2011 Dodge Charger
Reset change oil light
hello, here is the instructions on how to reset the light
When the system has calculated that oil life has been diminished, it will indicate that an oil change is necessary. A CHANGE ENGINE OIL SOON message will come on. Change the engine oil as soon as possible within the next 600 miles (1000 km). It is possible that, if driving under the best conditions, the oil life may not indicate that an oil change is necessary for over a year. However, the engine oil and filter must be changed at least once a year and at this time the system must be reset.
If the system is ever reset accidentally, change the engine oil at 3000 miles (5000 km) since last oil change.
To reset the Engine Oil Life System, do the following:
  1. Turn the ignition to ON, with the engine off.
  2. Slowly fully press and release the accelerator pedal 3 times within 5 seconds.
  3. The reset is complete when the chimes sound and the CHANGE OIL lamp goes out. If the lamp stays on and no chime is heard, repeat the reset procedure.
  4. Turn the key to OFF.
If the CHANGE OIL lamp comes back on when the vehicle is started, the engine oil life system has not reset. Repeat the procedure.
Jun 20, 2010 | 2001 Pontiac Grand Am SE
How do i reset the oil light on my 95 fleetwood cad
Oil Life Indicator
1. Oil life indicator will display CHANGE OIL when oil change is needed, based upon engine oil temperatures and driving patterns. After changing oil, reset
oil life indicator.
2. To reset, turn ignition switch to ON position. Do not start engine. Fully press and release accelerator pedal 3 times within 5 seconds. If CHANGE OIL light
comes on and stays on for 5 seconds, it did not reset. Reset system again.
Jun 08, 2010 | 1995 Cadillac Fleetwood
Just had oil change done on my 2000 alero now my service engine soon light is on.I want to know what this means
It simply means that the service indicator was not reset when the oil was changed. If the oil was changed professionally, then resetting the service indicator is usually part of the job.
It's not just a reminder to change the oil, it's also there to remind you to check/adjust/lubricate/replace other items such as the air filter, oil filter, spark plugs, fuel filter, dampers (UK=shock absorbers) etc.
The service indicator is simply a dumb counter keyed to mileage and time elapsed and cannot sense when you have completed a service. Resetting the indicator requires a special tool so you'll need to take your car to a suitably equipped garage.
May 03, 2010 | 2000 Oldsmobile Alero
2007 ion change oil light still on after oil change
your computer needs to be reset. the mech who changed your oil should be able to help you out with that. If you did it your self just visit Saturn they can advise how to do this. It may also be in the owners manuale, though it usually is not.
Feb 26, 2010 | 2005 Saturn ION
Resetting oil indicator
if you still have the owners manual i would check there
Mar 20, 2009 | Saab 9 3 Cars & Trucks
I changed my oil on my LX and the change oil warning is not reset
On LX and EX models
If maintenance is done by someone other than your dealer, reset the maintenance minder as follows:
1. Turn the ignition switch to ON ( II ).
2. Press the SELECT/RESET knob until the engine oil life indicator
is displayed.
3. Press the SELECT/RESET knob for about 10 seconds. The engine oil life indicator and the maintenance item code (s) will blink.
4. Press the SELECT/RESET knob for more than 5 seconds. The maintenance items code (s) will disappear, and the engine oil life indicator will reset to "100".
Jan 01, 2009 | 2004 Honda Odyssey
1999 Pontiac Grand Prix lights are staying on
what is the procedure you are using can you explain it to me?
Resetting Procedure
To reset the CHANGE OIL SOON indicator if equipped with the Driver Information Center (DIC).
  1. Turn the ignition to ON without starting the engine.
  2. Fully press and release the accelerator pedal three times within five seconds.
    • If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF then start the vehicle.
    • If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure.
To reset the OIL LIFE indicator if equipped with a Trip Computer.
  1. Press the trip MODE button until the light appears next to OIL LIFE.
  2. Press and hold the trip RESET button until the oil life percentage changes to 100%.
Hope this helps Ill look into the ABS lights but I do believe that you will need a scan tool to retreive a code to be able to diagnose the reason for the lights
Sep 18, 2008 | 1999 Pontiac Grand Prix
Chrysler 2011 200 LX Logo
50 people viewed this question
Top Chrysler Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
ray gallant
Lawrence Oravetz
Are you a Chrysler Heating and Cooling Expert? Answer questions, earn points and help others
